Multi Function Steering Wheel Problems
DDalgarn
Post by DDalgarn » Mon Jan 27, 2014 1:19 pm
I've got a 2004 RS4 avant and it came with the standard non- flat bottom multi function sterring wheel, however I've just fitted a newer flat bottom multi function steering wheel but I now the horn doesn't work and none of the other functions on the wheel. Any suggestion what I need to do to sort the problem?
Adamcell
Re: Multi Function Steering Wheel Problems
Post by Adamcell » Mon Jan 27, 2014 1:38 pm
You may need VCDS to get it working.
manual_daniel
Post by manual_daniel » Mon Jan 27, 2014 3:27 pm
DDalgarn wrote:I've got a 2004 RS4 avant and it came with the standard non- flat bottom multi function sterring wheel, however I've just fitted a newer flat bottom multi function steering wheel but I now the horn doesn't work and none of the other functions on the wheel. Any suggestion what I need to do to sort the problem?
What year is your car?
I did this retrofit on my 2007 car, round MFSW to TTRS FBMFSW. I had an issue with the wiring loom, the new airbag (different part #) had two ground wire terminals as opposed to the old one (round wheel) having one wire terminal. I ordered a new wiring loom from HazzyDayz and it solved the problem. Does this sound similar to your problem?
Now: 2007 Daytona RS4 Avant
Passed On: 2003 Mugello RS6 Sedan
DDalgarn
Post by DDalgarn » Mon Jan 27, 2014 5:10 pm
It sounds at though its the same problem, I've dropped Hazzy Dayz and email to see what they can do. Thanks:)
Rick_RS4
Post by Rick_RS4 » Mon Jan 27, 2014 5:52 pm
as said above you need it coding to the new wheel.
Users browsing this forum: Majestic-12 [Bot] and 96 guests
