10mm spacers all round???
- Firestarter
Chaps
Im looking to try out some spacers in order to give Mr T a wider stance. I know that most have gone for 10mm on the rear and 8mm on the front. Has anyone actually gone 10mm all round and if so can the supply a pic and also advise if there has been any adverse effect with steering wobble?
Thanks guys
Louie
Thanks guys
Louie
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Re: 10mm spacers all round???
I've actually got 15mm on the rear and 10mm on the front! Lowered on h&r springs! Looks just right! Gives a nice wide ass!
RS4 B7 Saloon
Phantom Black
Black optics
Non-res milltek - non valved - gutted pre cats
LED interior lighting
LED's all round - xenon DRL's
19" standard alloys in graphite grey
H&R springs
H&R spacers
Phantom Black
Black optics
H&R springs
H&R spacers
- Firestarter
Thanks Cal, I like the sound of that! Any pics bud?
Have you had any wheel wobble issues with the front 10mm spacers? Also what's ya ride height from ground to centre of wheel arch?
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Only got pics with only the rears on here as haven't took any new ones yet! No wobble at all and never actually measured the ride height but I know the springs drop them around an inch and a half lower! Looks just right tbh. Considering the difference in price compared to coilys!
RS4 B7 Saloon
Phantom Black
Black optics
H&R springs
H&R spacers
Phantom Black
Black optics
H&R springs
H&R spacers
- Firestarter
CheeRS Cal Looks good dude!
One last thing are you running standard 255/35 and if so what make? I ask as mine was fitted with P-Zeros and I know these have a fairly large wall so just want to make sure I'll be OK. I have removed the front inner arch bolts so am all set!
Thanks for your help dude
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Spacers, no matter what the size, will not give you any wheel wobble
2007 Daytona Grey RS 4 Avant
2013 Daytona Grey RS 4 Avant
Cheers mate! Yh running exactly the same as you mate with arch bolts removed as well!
RS4 B7 Saloon
Phantom Black
Black optics
H&R springs
H&R spacers
Phantom Black
Black optics
H&R springs
H&R spacers
Louie - you should be fine with 10mm and pirelli's - its the Good Years that can be a little troublesome. I run 8MM all round but my car is pretty low with GY ASSM 2 [255's] - I dont have any stability issues with the KWV3 setup - just make sure the hub/wheel surface is good and clean/true with no Hammerite on the surfaces!Firestarter wrote:Chaps
Thanks guys
Louie
One of the main reasons why "we" run 8mm up front initially with certain tyre makes was so that it dint fail a MOT, as some brands was rubbing on the arch liner.
As above, you should not get any wheel wobble with hub-centric spacers, I have seen the shim type spacers been put on incorrectly causing it to be off set, this will cause the wobble. Also if you have nay dirt stuck between the face of the spacer (or wheel) will cause the wheel to wobble. I have personally seen this happen to the point where the wheel actually fell off and rolled up the road.
- Firestarter
Hi guys
Thanks for all your responses and help on this. Some good pointers (Kev I'll loose the Hammerite)
and Sonny (I'll ensure the faces are spotless)
Have purchased 10mm for fronts and 15mm for rears. These will be with me on Tuesday so will fit and report back ensuring Rule 1 is followed
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Users browsing this forum: Google [Bot] and 105 guests
