I do have a couple of issues with it though.
I have noticed that the revs do not drop very quickly when you take your foot off the throttle, this happens whether driving or stationary.
The idle seems to be quite high when you first come to a standstill or still rolling slightly then they drop down to normal, when at normal idle revs it does not idle smoothly, it hunts up and down very slightly.
When giving it the beans there seems to be a very slight vibration through the car which seems to stop when you take the foot off the throttle.
I have run the VCDS on her and after resetting all the historic codes it has come back with the clutch switch and knock sensor so I will replace these. Any ideas on what could be causing my other issues? Thanks
