Squeaky engine noise?
Blairh2
Post by Blairh2 » Sat May 11, 2013 2:37 pm
Hi all,
I was almost home from a 150 mile drive where I was giving the car some gentle thrashing and when I got back into 30 mile zone I could hear a faint squeaking/whirring noise coming from the engine bay. When I slowed down to 5-10 miles it got very loud. When I got home I tried to locate and it seems to be coming from front left'ish (if you're looking at the car), right behind the front grill.
To me it sounds like a rubber belt could be slipping??
Any suggestions?
thanks
jaysrs4
Re: Squeaky engine noise?
Post by jaysrs4 » Sat May 11, 2013 6:06 pm
Tensioner/Idle pulley? Sounds the most likely culprit.
moondog
Post by moondog » Mon Jun 17, 2013 8:29 pm
Just bought a second hand '06 RS4 2 weeks ago, similar problem. Wasnt apparent on test drive, but developed intermittently, and last saturday became a full on screech. Sounded like an idler/tensioner bearing failing, but in audi workshop today and all bearings ok. Tech said it disappeared when a vacuum hose taken off around oil filler cap, but no diagnosis as yet. Very odd. Will post any results. Any ideas welcome.
Daytona B7 RS4 Avant soon to be terrorizing NZ roads.
moondog
Post by moondog » Tue Jun 18, 2013 8:39 am
Oil seperator needs replacing apparently. Hope this helps anyone with a similar problem, and saves them 500 odd quid that audi would charge them. I would never have found it myself
adsgreen
Post by adsgreen » Tue Jun 18, 2013 11:15 am
was a good clue about the vacuum - does limit the possibilities down.
And a good lot cheaper than timing tensioners!
moondog
Post by moondog » Tue Jun 18, 2013 11:33 am
Yeh, hope it helps someone out. I can see owning a RS4 is going to be a steep learning curve for me to maintain myself when I get it to New Zealand in a couple of months. Last car I really worked on was my mk1 Cortina 20 years ago! Looking foward to the challenge. Re tensioners: I meant the idler/tensioner on poly-v alternator drive, not timing.
Users browsing this forum: No registered users and 52 guests
