Smoke is doin my head in what can it be
Jamiestanton
Post by Jamiestanton » Sat Apr 13, 2013 6:24 pm
No smoke when I boot it only get it if I drive steady then pull up at the lights then when i pull off get a cloud of what looks like blue smoke can not be inlet as car don't feel sluggish and was last done 2 years ago by the last owner what else can it be
2006 black audi rs4 b7 mrc stage 2 stage 2 manifold de cats miltek coil overs light weight flywheel black optics 445bhp 470nm
adsgreen
Re: Smoke is doin my head in what can it be
Post by adsgreen » Sat Apr 13, 2013 9:24 pm
A lot can go wrong in two years so I wouldn't be too quick to discount anything.
What's the oil level like?
zed_hn
Post by zed_hn » Sat Apr 13, 2013 9:36 pm
Have a look at the pcv oil valve
Jamiestanton
Post by Jamiestanton » Sun Apr 14, 2013 10:25 pm
zed_hn wrote:Have a look at the pcv oil valve
What should I be looking for if this is the problem
sonny
Post by sonny » Sun Apr 14, 2013 11:40 pm
Have you checked the oil level? Overfilled oil can be dumped in the burn phase and show as blue/white smoke.
Jamiestanton
Post by Jamiestanton » Wed Apr 17, 2013 12:08 am
Only get smoke on stand still if I rev it on the spot don't get it driving
adsgreen
Post by adsgreen » Wed Apr 17, 2013 7:17 am
Yes yes yes but two people have asked if you have checked the oil.
We are trying to help but need some feedback ;)
Jamiestanton
Post by Jamiestanton » Wed Apr 17, 2013 9:13 am
Sorry yes checked oil 300 mile ago was on full now just below put 1/4 or a liter in back on full
Jamiestanton
Post by Jamiestanton » Wed Apr 17, 2013 9:24 am
One more point I had the car about a month it was sluggish when I picked it up I must have been choked up because I drove it hard for a few days and now its drives great since then car has had all oils changed new coil packs new plugs air filter have done a full service on it
Spaceman_RS4
Post by Spaceman_RS4 » Wed Apr 17, 2013 9:50 am
Pretty sure the oil shouldn't be run on full bud. But below it in the hatched area, it's perfectly possible there's too much in it and is burning some. Take you checking the oil after getting it fully warm then switched off left to settle for a few mins then checked
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
RIV
Post by RIV » Wed Apr 17, 2013 11:54 am
Ive allways been told its best to keep between half way up and max on the dipstick
adsgreen
Post by adsgreen » Wed Apr 17, 2013 12:29 pm
The ideal is 3/4
Full enough that you won't get any surge but not over filled so that you start burning it.
Going from full to 1/4 in 300 miles on fresh oil is massive.
That's either a leak or some other failure.
Firstly you need to conclusively establish where it's being burnt.
Get the car up to temperature and let idle for a but. Then ask a mate/partner to blip the throttle and see if the oil is actually coming out of the exhaust. Sometimes a leak in the engine bay can hit warm components and burn off but from the drivers seat it looks like its coming out the back when you pull away.
If its not out the exhaust then get it on a ramp and checked ASAP.
Oil fires can be very nasty and very quick. Not worth taking the chance.
If its te exhaust then the first thing to check would be the above - th pcv valve.
Iirc it's by the oil filter under the carbon cover near the back of the engine.
You'll need to remove and inspect for any damage or cracks.
This is by far the cheapest thing to replace.
If not this then look for vacuum issues. The pcv has a vacuum valve that opens to release the caught oil to the sump. If this never opens then it'll back up and send oil into the intake.
Lots in the archives.
After this its looking more like internal engine component but let's cross that bridge when we get to it.
pDkALO
Post by pDkALO » Wed Apr 17, 2013 1:03 pm
ads - all good info, but the op has said:
Jamiestanton wrote:One more point I had the car about a month it was sluggish when I picked it up I must have been choked up because I drove it hard for a few days and now its drives great since then car has had all oils changed new coil packs new plugs air filter have done a full service on it
.... so surely the first point is to go back to dealer (presumably Audi as packs were done?) and ask then why it's now blowing smoke since being serviced? I know that's what I'd do.
Current: Macan Turbo, Boxster 987 S
Gone: RS6 C6 Avant, RS4 B7 Avant, Tamora Speed Six
PetrolDave
Post by PetrolDave » Wed Apr 17, 2013 5:30 pm
Silas wrote:Ive allways been told its best to keep between half way up and max on the dipstick
Remember that on the RS4 the oil level should be checked when it's warm (not hot), so if you fill it up to max when cold then it's overfull.
RIV
Post by RIV » Wed Apr 17, 2013 5:37 pm
Remember that on the RS4 the Oil level should be checked when it's warm (not hot), so if you fill it up to max when cold then it's overfull.
Yep always check when warm, and I never fill to max
Users browsing this forum: No registered users and 181 guests
