Tyre Pressure warning errors
adriangwatson
Hi guys. I've tried researching this question on here but still a bit confused....
I have a permanent Tyre Pressure red light warning come up on the DIS. I've checked the tyre pressures a couple of times now and the tyre pressures are fine.
Does this mean that the batteries in the tyre sensors are probably flat? I have an 06 model which I have only had for a year, and am not sure whether they have ever been replaced. Is there any way I can easily check?
Does it make most sense to just take it to an authorised dealer or am I best off just buying some new sensors online and getting a tyre Shop to fit them?
Thanks for any advice
Re: Tyre Pressure warning errors
Have you reset the pressures in the computer menu ?
Vag Com should tell you the error code but yes, likely the batteries are flat.
adriangwatson
Hi, I'm not sure if I can because the red light seems to block out the functionality on the DIS.D8vil wrote:Have you reset the pressures in the computer menu ?
You can - I had this at the weekend. Just follow the instructions in the handbook to reset the pressures to the current value. Fixed my red warning sign...
- alex020869
Anyone know if the sensors are expensive to replace?
Alex
Alex
RS4 B7 Mugello Blue Saloon
alex020869 wrote:Anyone know if the sensors are expensive to replace?
Alex
80-100 quid each plus fitting and possibly valves.
- alex020869
Can the batteries be replaced or are they sealed units?adsgreen wrote:alex020869 wrote:Anyone know if the sensors are expensive to replace?
Alex
Alex
- PetrolDave
They're sealed units.alex020869 wrote:Can the batteries be replaced or are they sealed units?
adriangwatson
Thanks, will give it a go. Fingers crossed. Having to spend £400+ on tire pressure sensors seems pretty punchy.....GLOL wrote:You can - I had this at the weekend. Just follow the instructions in the handbook to reset the pressures to the current value. Fixed my red warning sign...
- PetrolDave
VCDS can tell you which of the sensors have dead batteries.adriangwatson wrote:Having to spend £400+ on tire pressure sensors seems pretty punchy.....
spikeyboy101
i keep getting a yellow flat tyre symbol with a line through it - comes on for a while and goes off.
Tyres are always ok on pressures - diagnostic just gives a general error and doesnt point the finger at anything particular - any ideas ?
Think yours is turned off then.
- PetrolDave
Try looking at the measuring blocks, that's where the details of pressure, temperature and battery voltage can be seen for each tyre.spikeyboy101 wrote:i keep getting a yellow flat tyre symbol with a line through it - comes on for a while and goes off.
adriangwatson
Thanks for the advice - I reset the values and it seems to have done the trick.GLOL wrote:You can - I had this at the weekend. Just follow the instructions in the handbook to reset the pressures to the current value. Fixed my red warning sign...
Users browsing this forum: Google [Bot] and 360 guests
