Esp+Epc+Limp Mode
parahandy
Esp+Epc+Limp Mode
Post by parahandy » Thu Oct 11, 2012 9:00 am
Hi
Last Saturday I'd just left the house with the RS and was picking up speed when the engine went into limp mode showing the ESP and EPC warning lights.
I switched the engine off - restarted the car,which showed the ESP light had reset itself and engine power was back to normal. The EPC light remained lit.
I plugged in VCDS and ran an auto scan which showed the fault codes shown below.I reset the EPC light and drove the car for about 500 miles with no problems until last evening when the same problem occurred. I haven't checked for codes but I'm expecting it to show the same ones as last Saturday. Having stopped the engine and restarted it the car is flying again.
The car pre cats have been removed which accounts for some of the fault codes and triggers the Emission light which has been lit for some time and is a separate issue.
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WUAZZZ8E87N904082 Mileage: 84320km/52394miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0080
Revision: --H13--- Serial number: XXXXXXXXXXXXXX
Coding: 01040003180F0160
Shop #: WSC 00191 264 15243
VCID: E3CF05BB221FE000DC7
2 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 84326 km
Time Indication: 0
Freeze Frame:
RPM: 170 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 9.0°C
Temperature: 14.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 10.287 V
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 004 - Malfunction / Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 84326 km
Time Indication: 0
Freeze Frame:
RPM: 1248 /min
Load: 61.2 %
Speed: 0.0 km/h
Temperature: 12.0°C
Temperature: 13.0°C
Voltage: 13.462 V
Readiness: 0110 1100
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B5F2D9B8A4FE840A47
2 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 13
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4002
Hex Value: 0x0013
Hex Value: 0x85AD
Hex Value: 0x0001
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Time Indication: 0
Freeze Frame:
Hex Value: 0x6600
Hex Value: 0x4002
Hex Value: 0x0028
Hex Value: 0x01AB
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00001
Shop #: WSC 06335
VCID: 6DDBE38327DB2670FA3
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00041
Shop #: WSC 06335
VCID: 3D7B13C3373B76F00A3
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
Shop #: WSC 00010 210 86725
1 Fault Found:
008599 - Oxygen (Lambda) Sensor B2 S1
P2197 - 008 - Signal too Low (Lean)
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 84326 km
Time Indication: 0
Freeze Frame:
RPM: 881 /min
Load: 31.0 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 21.0°C
Voltage: 13.970 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G45GXJ
Coding: 0430612
VCID: 3B7F1DDB7A2F78C0347
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 02441
Shop #: WSC 06335
VCID: 448D662754D1073845D
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 R HW: 8E0 920 981 R
Component: KOMBI+WFS 4 H14 0050
Revision: 0050 Serial number: 00000000000000
Coding: 0023411
VCID: 3C7D1EC77C217FF83DD
1 Fault Found:
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760 A
Component: Sitzverstellung H01 0020
Coding: 00001
Shop #: WSC 06335
VCID: 326130FFFE65B988E71
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
Component: RNS-E HIGH EU H73 0650
Revision: 02S Serial number: AUZBZ7F1194612
Coding: 0309117
Shop #: WSC 00762 210 15551
VCID: 2C5D2E878C41EF78ADD
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 4
Reset counter: 191
Time Indication: 0
Date: 2012.10.02
Time: 13:14:48
Freeze Frame:
Mileage: 655350 km
Count: 810
Clock: 10:01
Monday,08,October,2012,14:26:48:19160
VCDS Version: Release 11.11.4
Data version: 20120807
69 75 76 77
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 84326 km
Time Indication: 0
Freeze Frame:
RPM: 170 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 9.0°C
Temperature: 14.0°C
Voltage: 10.287 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 84326 km
Time Indication: 0
Freeze Frame:
RPM: 1248 /min
Load: 61.2 %
Speed: 0.0 km/h
Temperature: 12.0°C
Temperature: 13.0°C
Voltage: 13.462 V
Coding: 0004533
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 13
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4002
Hex Value: 0x0013
Hex Value: 0x85AD
Hex Value: 0x0001
18265 - Load Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Time Indication: 0
Freeze Frame:
Hex Value: 0x6600
Hex Value: 0x4002
Hex Value: 0x0028
Hex Value: 0x01AB
Hex Value: 0x0001
Coding: 00001
Shop #: WSC 06335
Coding: 00041
Shop #: WSC 06335
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 84326 km
Time Indication: 0
Freeze Frame:
RPM: 881 /min
Load: 31.0 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 21.0°C
Voltage: 13.970 V
Coding: 0430612
Coding: 02441
Shop #: WSC 06335
Coding: 0023411
1 Fault Found:
Coding: 00001
Shop #: WSC 06335
Coding: 0309117
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 191
Time Indication: 0
Date: 2012.10.02
Time: 13:14:48
Freeze Frame:
Mileage: 655350 km
Count: 810
Clock: 10:01
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: EBDF6D9B99CFA840647
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 06891
Shop #: WSC 06335
VCID: 79F3C7D363938AD066B
Subsystem 1 - Part No: 8E2959802F
Component: Tõrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E2959801F
Component: Tõrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 2953D79380B3FA5056B
Part No: 8E0 941 329 A
Component: AFS-Modul links H03 0020
Component: AFS-Modul rechtsH03 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309117
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 191
Time Indication: 0
Date: 2012.10.02
Time: 13:14:48
Freeze Frame:
Mileage: 655350 km
Count: 810
Clock: 10:01
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022523
Shop #: WSC 02197 785 00200
VCID: 2A51289F86B5F1485F1
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
Component: Parkhilfe 8-Kan H06 0010
Revision: 00H06000 Serial number: 00067802130629
Coding: 0000104
VCID: 326130FFAE65B988E71
End ---------------------------------------------------------------------
Can anyone help as to what is causing the problem, which would be dangerous if it were to happen pulling out of a junction or overtaking?
And another wee question. Will the right hand engine mount Solenoid valve fault code trigger the Emission light, and what does the solenoid do?
Calum
ROY
Re: Esp+Epc+Limp Mode
Post by ROY » Thu Oct 11, 2012 9:08 am
Holy <beep> !!!
That a lot of errors :shock:
Gone but not forgotten boohoo !!!
RS4 Sprint Blue Avant on Dyno after Carbon Clean http://youtu.be/7lsBbmmaDQc
TimDogg
Post by TimDogg » Thu Oct 11, 2012 11:45 am
Yeah but it could be that the FBSW was changed from stock, RNS-E added etc. I'd get the car to MRC, Rev or Unit 20 for a look.
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
adsgreen
Post by adsgreen » Thu Oct 11, 2012 12:54 pm
~Now that you have the log it's probably worth reseting the error codes and see what reoccurs.
Some of those errors look like random tangents (like the alarm for example) so it's hard to see what the actual problem is.
Many of those errors also wouldn't light up the EPS light on their own.
adsgreen
Post by adsgreen » Thu Oct 11, 2012 12:55 pm
Mileage: 655350 km
eh?
P_G
Post by P_G » Thu Oct 11, 2012 2:24 pm
If you askng what the problem is then it will be linked to lambda sensor sending it into limp mode. Right engine mount solenod will not do this. If you have gutted pre cats the lambdas will send t into limp maode, you need them 'mapped out' so that the ECU's don't try to read from them. The others are occassional codes and resetting will probably show this.
Users browsing this forum: No registered users and 159 guests
