Sticky clutch - again..
- 1st Gear
Hi,
Went to Newcastle Audi as car still under warranty as after hard driving my clutch pedal on occasions sticks down (have had to flick the pedal up with my foot!)
I explained I thought was a clutch return pipe issue but they want to take the gearbox out and have a proper look - they said would be £600 to do this and if its under warranty then i wont get charged...
Its a bit of an expensive 'risk' when they aren't sure of the problem
Any advice?
Cheers.
Any advice?
Cheers.
Re: Sticky clutch - again..
Clutch return pipe doesn't always cure it although since I've had mine properly done it hasn't happened since so fingers crossed. I went for cheapest process of elimination route which I advise. Gearbox out seems a piss take IMHO!
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
- 1st Gear
well thats what i thought too!!
can i ask for the pipe to be replaced under warranty? - simple enough job?
Given that it's a know fault surely it's the obvious check - ESP as can be done insitu via dfront drive shaft removal. Bit cheaper than a gearbox check.
I think Timster got his done under warranty. The pipe's cheap and it doesn't take long to fit.
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
- 1st Gear
Thanks for that - I will see what they say
I think MRC charged me £115.00 all in.
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Yes indeedy:Shagga wrote:I think Timster got his done under warranty. The pipe's cheap and it doesn't take long to fit.
http://forum.rs246.com/viewtopic.php?f=35&t=93246
"Search" is your friend.
having mine done next week
same time the DRC (w/ H&R springs) is done
also having z thermal insulation sleeve put on the hose (I'm supplying it) and having the slave cylinder done (60k miles, plastic, and they seem to fail with age)
told them I'll pay for the cylinder and additonal install labor (should be minimal once acess is obtained for the hose replacement), I bet they include it under the CPO anyways
Look forward to hearing how the insulation sleeve goes Arthur.
Where are you getting the sleeve from Arthur?
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
got this stuff...Shagga wrote:Look forward to hearing how the insulation sleeve goes Arthur.
http://www.jegs.com/i/Thermo+Tec/893/17150/10002/-1
a bit larger so there will be an air gap (air is a good insulator, low heat transfer)
any hotrod shp should have something similar
Pretty standard stuff as Arthur says - demon tweeks have lots of suitable stuff. Does do a grand job - I used it on the 211 lots as the charge cooler radiator is really susceptible to heat soak. Dropped inlet temps by over 20c.
Nice one guys.
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Users browsing this forum: No registered users and 112 guests
