Oil Consumption - is this normal?
Dave.B
Post by Dave.B » Mon Nov 21, 2011 10:30 pm
Hi,
Oil check level came on at the weekend after a 300 mile round trip to Edinburgh.
Oil was replaced with 5w30 Catsrol edge - 10l in Sept - done approximately 3500 motorway miles mainly since
Seems an awful lot.... - anything I need to be aware of/check
adsgreen
Re: Oil Consumption - is this normal?
Post by adsgreen » Mon Nov 21, 2011 10:57 pm
Oil cooler pipes known to corrode.
Does look like fresh oil so unlikely to be that unless you drive with your hair on fire.
But 1 litre in 3500 miles isn't awful.
Dave.B
Post by Dave.B » Mon Nov 21, 2011 11:01 pm
at what level does the oil light come on?
adsgreen
Post by adsgreen » Tue Nov 22, 2011 12:30 am
Depends - some are more sensitive than others but I'd guess about 1.5 litres from max ish.
How much did you put in?
P_G
Post by P_G » Tue Nov 22, 2011 9:04 am
IIRC the volume between min. and max. is 1 litre which ties in nicely with the 1l top up you get in the boot.
adsgreen
Post by adsgreen » Tue Nov 22, 2011 9:16 am
Yup but the light is a fussy thing - some come on early but most come after the oil has dropped off the dipstick
P_G
Post by P_G » Tue Nov 22, 2011 9:19 am
True, it took up to 1.25 litres last time for the light to go off and then there is the time it takes the bubble to settle again in the oil sensor so that is goes out. I tend to check regularly but caught out last time around.
Post by Ian_C » Tue Nov 22, 2011 11:04 am
adsgreen wrote:But 1 litre in 3500 miles isn't awful.
I'd be well happy if mine only used 1 litre in 3500 miles! I think I've got through about 6 litres in 7k (4163cc S4)
Dave.B
Post by Dave.B » Tue Nov 22, 2011 11:19 am
Ah I see - I thought when the light came on it was more than 1.5 litres used up!!
Agree - 1l aint bad over 3500 miles - was filled up when filter done too so was full
adsgreen
Post by adsgreen » Tue Nov 22, 2011 12:33 pm
be interesting to see what oil was used - I tend to find with top notch modern fully synths that there isn't any oil useage until about 7k miles then it starts to breakdown and by 10k miles it's quite high but still nothing to worry about.
ArthurPE
Post by ArthurPE » Tue Nov 22, 2011 5:33 pm
mine uses ~1/2 liter per 5000 miles
PetrolDave
Post by PetrolDave » Tue Nov 22, 2011 6:59 pm
I've noticed the same as adsgreen.
In the few months after a service mine using 1 litre per 5k miles, but as it gets closer to a year or 10k the oil usage increases noticeably to about 1 litre per 2k miles.
Audi have always said that 1 litre per 1k miles is normal.
BlingBling
Post by BlingBling » Wed Nov 23, 2011 10:26 am
adsgreen wrote:be interesting to see what oil was used - I tend to find with top notch modern fully synths that there isn't any oil useage until about 7k miles then it starts to breakdown and by 10k miles it's quite high but still nothing to worry about.
And to think Audi put these engines on 20k service intervals :bash:
adsgreen
Post by adsgreen » Wed Nov 23, 2011 11:50 am
To be fair, 20k intervals are fine with modern oils if you don't mind the consumption increasing near the end. However it needs to be mainly motorway miles without lots of thrashing/revs and thats just isn't in keeping with the car. No one really is going to buy an rs4 and keep the revs under 4k which does make it an interesting question. So for the RS4 no, I don't think they should have offered 20k intervals but perhaps 7.5k/1year or 15k/2 year variable.
BlingBling
Post by BlingBling » Wed Nov 23, 2011 4:44 pm
TBH I do not think 2yr/20k services are suitable for most modern day performance cars. Even though oil technology has improved it still breaks down. Some more than others even if they meet the manufacturers spec. I service my car annually even though I do about 5k.
Users browsing this forum: Google Adsense [Bot] and 111 guests
