trolley jack ?
trolley jack ?
if i decide to keep my car (which is very likely), wot do other members
do regarding trolley jack and spare wheel, ie only use on long trips, space saver wheel
light weight jack, which make/model.
- PetrolDave
Re: trolley jack ?
My trolley jack won't fit underneath . I boght a standard A4 jack and modified the plastic in the spare wheel wheel with a Stanley knife so it fits in there.
And I have an Audi space saver 18" wheel in a tyre bag which I carry at all times.
Re: trolley jack ?
dave wot sought of price are the space saver and
are they from audi or just a cheap get me home
- PetrolDave
Re: trolley jack ?
The wheel is genuine Audi, and the tyre is a Vredestein space saver.tempo wrote:dave wot sought of price are the space saver and
Re: trolley jack ?
Halfords do a 2 ton trolley jack, which is slimline.tempo wrote:if i decide to keep my car (which is very likely), wot do other members
Easily fits underneath the RS. Has it's own toughened-plastic case.
Bit chunky to lug around all the time though (as any trolley jack, would be).
Also... Costco sometimes do a 3 ton jobbie, which looks to have a lot of aluminium components.... so may be worth checking.
(Daves idea of a standard A4 jack is probably better though... if you're just using it for journeys)
Re: trolley jack ?
You can get a bottle jack from Halfords for less than £10 which is what I have for longer journeys and it does the job. IIRC it is good enough for 1.5 tonnes which is more then enough for one corner and fits in one of the two compartments next to the battery.
Re: trolley jack ?
To be fair I would not bother with a trolley jack, as PG says, a bottle jack will be just fine. If you feel you must need a trolley jack then the Halfords one is good enough, If your car is lowered more than 20mm then forget it as it wont fit. I have the Halfords one, I will sell it to you half the price of the one for sale.
I upgraded to a Sealey aluminium low profile track for my track days. money well spent.
Re: trolley jack ?
my car has the sports sus plus lowered 20mm so it looks if
i might have to go the same route and get a sealey low profile.
dont realy fancy a bottle jack! also some spacesaver wheels on flea bay
but for an a3, will this fit the rs4?
Re: trolley jack ?
http://www.machinemart.co.uk/shop/produ ... sion-jacks
http://www.pistonheads.com/gassing/topi ... 02197&nmt=
I went for this one
http://www.silverstonefactors.com/index ... =component
I went for this one
Re: trolley jack ?
cheers sonny, the sealey and clarke are the ones ive been looking at.
pretty light weight too if carrying around all the time.
by the way, good video
Re: trolley jack ?
tempo wrote:cheers sonny, the sealey and clarke are the ones ive been looking at.
mate, just go to the breakers and get a std audi/vw scissor jack,thats all you need if it just to carry for a spare change,they fit in the plastic tray under the boot also
i just robbed the one that came with my tts when i traded it,(or you could just look in the boot if you get a loan car
as for a spare i just carry a full size alloy and bolts that i have had for years in the 2x tt's i had,takes a bit of space but i'm to tight to buy a spacesaver,think i paid about £100 for a new alloy with a new tyre,both are cheapys but its just a get you home and it looks better than a spacesaver plus no rush to get your puncture fixed so you can shop around for a good price for a replacement tyre
Re: trolley jack ?
I have this one which lifts the car OK & fits under the plastic blocks fine (I also use a bit of wood to protect the blocks) am on non-SS suspension & is only 30.
http://www.machinemart.co.uk/shop/produ ... olley-jack
If anyone wants to buy this sort of stuff get on Machine Mart's mailing list as they regulary send out 10% off offers.
