TURBO GURU WANTED
QCRS4
TURBO GURU WANTED
Post by QCRS4 » Sun Aug 14, 2011 2:33 pm
Hi, I'm looking to put a TT setup on my 2007 RS4. I thinking about doing something similar to the Heffner R8 v8 kit, 500whp at 6-8psi. So what will be the best turbo setup for this high comp high rev engine. Do you think that this turbo GT3582R A/R?...will do the job. As you already know I'm freaking High comp OEM so this is more CFM than PSI that I need.
thank's for you help
G.Mac
Re: TURBO GURU WANTED
Post by G.Mac » Sun Aug 14, 2011 6:30 pm
GT35 is a fair size of turbo, GT30's are making High 400's to mid 500's on Subarus!
I have a GT35/42 hybrid going on my 2.35 Liter and hoping for mid 600's once its finished
Graeme
edit
but saying that the above is on relatively low comp engines running decent boost (1.8 - 2 bar ish)
posterboyj
Post by posterboyj » Mon Aug 15, 2011 10:05 am
GT30 / GT35 setups on 1.8t engines making 350-400 due to insufficient airflow even at the rev limit
A 1 x GT40 would be perfect for a V8
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
QCRS4
Post by QCRS4 » Mon Aug 15, 2011 11:39 am
it's alsmost impossible to fit a single turbo set up on the RS4.
this what I'm looking to make. My budget is 20 000$USD
http://www.audizine.com/forum/showthrea ... b5-s4-rs4)
rwilsonrs4
Post by rwilsonrs4 » Mon Aug 15, 2011 11:46 am
I Applaud your enthusiasm for trying this :bowdown: ,i take it this will a track car or something ,with all unneccessary items removed ,With a road car theres hardly enough room in that engine bay for a mouse to crawl around lol, never mind 2 gt35s with all the pipework in there:-) but anything can be done i spose with enough time and money be awaesome when its done tho , hats off to you !
1/4 mile 12.01 secs 123.5mph
P_G
Post by P_G » Mon Aug 15, 2011 12:46 pm
I may be wrong but that looks like a C5 RS6 V8 engine, not the FSI V8 with turbo's bolted on? specifically that is belt rather than chain driven.
Post by bam_bam » Mon Aug 15, 2011 1:03 pm
P_G wrote:I may be wrong but that looks like a C5 RS6 V8 engine, not the FSI V8 with turbo's bolted on? specifically that is belt rather than chain driven.
Yep sure is. That B5 with C5 RS motor is pretty old that now. I wonder if the B5 engine bay is any smaller than the B7...
There was a recent 'Stateside B7 project that was to have a C5 RS engine fitted, I think it was abandoned for some technical reason.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Mon Aug 15, 2011 8:15 pm
Where are you going to fit a single turbo? the exhaust plumbing will be hard to make neat.
The Heffner R8s use big turbos and keep stock compression - I think you need to use smaller turbos so they physically fit in, but lower compression as well. 2 small gt30s on a 4.2(c5) with low compression do 780ps not pushed at all. We've been measuring up and have a test engine to try and get a setup that will work.
It is only worthwhile if it can do 650+ since the superchargers are getting close to 600.
http://www.MRCtuning.com
Users browsing this forum: Bing [Bot] and 154 guests
