No I did not get an EPC light, just no top end power, can't wait to do the CAF now.neckarsulm wrote:Did you get an EPC light?
Yes there was a vacuum their when the car was running but nor enough as it was leaking, it also would not hold the vacuum with the engine off.adsgreen wrote:If the manifold flaps were not working then you get a code thrown pretty quick. The ecu is pretty sensitive to what the flaps should and actually are reading.
Iirc if the there are circumstances where the ecu sees the vacuum leak, doesn't throw a code but limits the ignition timing resulting in dramatic power loss.
When you took the vac line off did you get a 'psssssss' noise?
I've just looked at the kit I think you have - where do you plan on putting the air intake? There's not a lot of room at the front and most specialists fit a caf by removing one of the auxiliary radiators in the bumper.HEo2TEC wrote:No I did not get an EPC light, just no top end power, can't wait to do the CAF now.neckarsulm wrote:Did you get an EPC light?
The CAF kit I have is the same that MRC fit, I have heard that you have to remove the aux rad and secondary air injection pump I'm hoping it can be done by just removing the aux rad as I'm not getting it remapped just yet, I should get an even better top end when I've done the CAF as my air filter power flap is not working.adsgreen wrote:I've just looked at the kit I think you have - where do you plan on putting the air intake? There's not a lot of room at the front and most specialists fit a caf by removing one of the auxiliary radiators in the bumper.HEo2TEC wrote:No I did not get an EPC light, just no top end power, can't wait to do the CAF now.neckarsulm wrote:Did you get an EPC light?
