Misfire
Guernsey70
Misfire
Post by Guernsey70 » Sun May 01, 2011 1:23 pm
Turned the S button on in 2nd gear, gave it some juice and at 5.5 rpm she started to misfire. Only happens in 2nd gear the first time the S button is switched on and then it clears.
Any ideas what this could be or why it happens?
G70
adsgreen
Re: Misfire
Post by adsgreen » Sun May 01, 2011 9:28 pm
unlikely to be related to the sport button - all it does is open exhaust flaps and change the throttle mapping for the accelerator pedal input.
RS4_Nick
Re: Misfire
Post by RS4_Nick » Mon May 02, 2011 4:44 pm
Could be the over-sensitive traction control if you're belting into the gears too hard.
Try again with traction control off using the same driving style. As previously suggested this should not be related to sport button.
Nick
sonny
Re: Misfire
Post by sonny » Mon May 02, 2011 5:26 pm
IIRC if it is misfiring the EML will flash.
Guernsey70
Re: Misfire
Post by Guernsey70 » Mon May 02, 2011 7:14 pm
Thanks, will try turning off the traction control.
G70
adsgreen
Re: Misfire
Post by adsgreen » Mon May 02, 2011 11:36 pm
sonny wrote:IIRC if it is misfiring the EML will flash.
Depends - it won't trip on one or two misfires. There needs to be a set amount over a given timeframe for it to trip the light.
sonny
Re: Misfire
Post by sonny » Tue May 03, 2011 8:53 am
Makes sense. :thumbs:
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 96 guests
