Clutch problem
k3ukr
Clutch problem
Post by k3ukr » Sun Mar 13, 2011 6:23 pm
Had a problem with my clutch last week ,symptoms were judder through the peddle and low bite point ,Audi had replaced the clutch under warranty in august and everything had been fine until last week ,I decided to strip it myself as my car is now out of warrenty expecting either the clutch pipe problem or a broken clutch or flywheel, As soon as I had taken the box out I discovered the clutch slack and a gap between the pressure plate and flywheel ,just wondered if anyone else has came across this before as I have seen some of the same symptoms in other posts
Cheers Kev
sonny
Re: Clutch problem
Post by sonny » Sun Mar 13, 2011 6:41 pm
Any pictures? I suppose you are lucky, Audi prob would have raped you if you took it in. :audibash:
I dont recall reading this as a problem on here, I suppose mot of us that are not Tech savvy would not know otherwise.
k3ukr
Re: Clutch problem
Post by k3ukr » Sun Mar 13, 2011 6:57 pm
Yea mate took some on the I phone. I will try and upload them later ,just posted to make people aware as they are probably getting charged over £1000 for a clutch and flywheel they don't need ,forgot to mention that I just took the bolts out, they have not stretched btw locktited them and stuck it back together with the same clutch and flywheel and it's fine.
Users browsing this forum: Majestic-12 [Bot] and 148 guests
