When is the need to replace all 4 tyres
My local Audi dealer has informed me that my current tread depth on my tyres measure 2/4/2 on both front tyres and 4/4/4 on the rear. They have stated that all four will need to be replaced when the front get to there limit due to the Quattro 4 x 4 system.
Is this neccesary as I assume that when the front tyres need to be replaced that the rears could still only be 50% worn.
Can anyone give me some advice, as before this statement I was going to replace just the two front tyres, but know I wonder if I need to wait and replace all four. I wonder what the maximus difference in the circumference of the tyre is related to the tread depth, there must be a guideline.
Current tyres are 255/35 x 19
Any help would be appreciated.
RE: When is the need to replace all 4 tyres
there is a maximum differential
iirc it's 2/32nd's
I'll try to dig it up, pretty sure it's been posted here?
iirc it's 2/32nd's
from Tirerack
Audi As published in their vehicle owner's manual, "rolling radius of all 4 tires must remain the same" or within 4/32-inch of each other in remaining tread depth.
I recall my dealer saying there musnt be more than a 4mm difference between front n rears. Actually I think I may have recalled incorrectly cos that's a big difference, doesn't sound right. Sorry, I'm no help lol.
B7 RS4 saloon Sprint blue facelifted. BMC AIR FILTER, 8mm REAR SPACERS, H &R lowering springs, NON RES VALVED MILTEK...(current)
Subaru Impreza P1 modded..330bhp (4yrs)
Merc 190e 2.5 16v cosworth..black with full black heated leather recaros ..200bhp (5yrs)
Cavalier 2.0 Sri 130bhp (5yrs)
4/32 just a tad over 3mm
Your rolling radius will be the same an all your tyres its only the edges that have feathered on your fronts and this is an rs4 thing it would seem,if this meens your full set of tyres are junk at 4mm then its a bit ott
- Steve_C
- Top Gear
I can understand a tyre wearing on either the inside or outside if the alignment is incorrect but how can it wear on both at the same time and not in the middle?
^ Low pressures?
2007 RS4 Avant in Mugello Blue + Milltek non-res valved, MRC air filter, MRC remap with silent-mode startup
So if you get an unrepairable puncture you need four new tyres or a dodgy part worn
- Revolution
- Trader (Expired)
sounds like under inflation to me also.
you should be able to get away with a pair on the same axle
then you have 1 spare for emergencies
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Just bought mine from Audi and when I looked the fronts were different makes, same brand on the rears. Asked Audi CS and they told me that as long as the tyres were the same on the same axle it was OK. Forced the dealer to replace both fronts to same make. They didnt seem to worried that the rears were about 6mm with new pair the front.
2007 RS4 Avus avant - now gone
2013 RS3 black - bye bye
2013 B8 RS4 - Sepang, Ceramics, Buckets, Carbon pack, Sports pack, ACC, B&O, privacy. - now gone
2017 C7 PE - Panther, Ceramics, Carbon pack, BO upgrade.
- PetrolDave
Re: RE: When is the need to replace all 4 tyres
Yep. Unless you want to risk damaging the centre Torsen diff.ShouldveBeenAGerman wrote:So if you get an unrepairable puncture you need four new tyres or a dodgy part worn
Many thanks to you all for your responses, it is now clear what I need to do and that is to wait a while and see what the tread depth differences are in about a months time. I think the statement about under inflation is correct as I have been running at 36 PSI all round since having the car 6 months ago, I have now pushed this to 39 PSI on the fronts and see what effect this has.
Users browsing this forum: No registered users and 183 guests
