Delay when changing gear
Hi all,
Just got in from a wee blast along the road.
I noticed when i was changing gear (quickly) it felt like there was a few seconds delay between me releasing the clutch till it got back on the power again. No sign of clutch slipping just felt a little odd as if there was delay in something engaging straight way.
Any thoughts.
Allan
Any thoughts.
Allan
Mint 57plate b7 RS4 Avant in black. Also RS 1600i project!!
RE: Delay when changing gear
Turn your traction control off....
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
The OP's throttle delay would be cured by a single stage button push (i.e. ASR off) - turning the full TC off could possibly lead to more serious outcomes...P_G wrote:Remember to keep the ESP button depressed for more then 5 secnds to have TC 'off' and the light permanently illuminated.
2007 Daytona RS4 Avant
Perhaps so however ASR still reigns in the power moreso than TC off so stage 1 may improve the power delivery but stage 2 would definitely.Dom81 wrote:The OP's throttle delay would be cured by a single stage button push (i.e. ASR off) - turning the full TC off could possibly lead to more serious outcomes...P_G wrote:Remember to keep the ESP button depressed for more then 5 secnds to have TC 'off' and the light permanently illuminated.
I always used to leave it on as the B7 doesn't quite have enough torque to overpower mechanical grip unless you're being a hooligan.
The only time I'd switch it off is when requiring a quick getaway from standstill when during the 1st to 2nd shift (and to a lesser extent 2nd to 3rd shift) it cuts power.
On the B5, its off all the time.
58 C6 RS6 Stage 2+
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Off when its wet!Steve_C wrote:How do most people set their car up? TC on, or off to stage 1 or 2? Or do you change it depending on the conditions?
Is there anyway you can go in through Vagcom and have TC disabled as default?
3.141
_________________________________
'14 C63 AMG Edition 507
'07 B7 RS4 +Milltek Non-Res, Non-Valved (Sold)
'10 YZF R1 + Akrapovics
