b7 rs4 recall - "oil pipe"
goron59
Post by goron59 » Thu Jul 08, 2010 9:31 am
Just had my local dealer call for a recall item: "oil pipe."
No more detail than that - anyone had this already, or knows any more info?
aidanjaye
Post by aidanjaye » Thu Jul 08, 2010 9:53 am
Had it done a few weeks ago - seems its just checking of pipes and clips. Mines was ok.
Nib
Post by Nib » Thu Jul 08, 2010 1:50 pm
The braded pipes that run to the oil cooler, which is in front of all the other coolers, can sometimes chaff leading to (possible) long-term failure. Dealers usually put a plastic ‘hose-holder’ between the pipes to prevent this.
Whilst they’re in the area the tech will also check for leaks from the cooler/hose unions and if found will probably replace hoses & cooler, as the hoses don’t come away easily. It’s a front-off job.
It's not a bad idea to then coat the unions with engine wax to prevent future corrosion before putting the front back on.
"It will never have enough power until I can spin the wheels at the end of the straightaway in high gear."
Mark Donohue on the 1,580bhp Porsche 917-30
goron59
Post by goron59 » Thu Jul 08, 2010 2:50 pm
Thanks for the info !
Current: 2008 R8 V8, all black.
Previous: 2007 B7 RS4 Saloon, mostly black.
PetrolDave
Post by PetrolDave » Thu Jul 08, 2010 7:18 pm
I've said this before and I'll say it again - items like this are NOT a recall (which is coordinated by VOSA and is for safety items ONLY), it is a Service Campaign and is OPTIONAL but advisory.
I've just had all the outstanding Service Campaign work done on my RS4 (paid for by the extended warranty), as well as a DRC replacement due to leaking front shock absorbers.
goron59
Post by goron59 » Thu Jul 08, 2010 7:39 pm
[quote="PetrolDave"]IYes, but the dealer refers to it as a "recall item," so that's how I call it.
drcarrera
Post by drcarrera » Fri Jul 09, 2010 11:53 am
PetrolDave wrote:I've said this before and I'll say it again - items like this are NOT a recall (which is coordinated by VOSA and is for safety items ONLY), it is a Service Campaign and is OPTIONAL but advisory.
Dave,
what other SC work did you have done (if you don't mind me asking).
Chris
06 Daytona RS4 Avant (B7)
P_G
Post by P_G » Fri Jul 09, 2010 1:40 pm
PetrolDave wrote: as well as a DRC replacement due to leaking front shock absorbers.
Your GenII finally succumbed? How are you finding it now it has Gen III on it?
Sims
Post by Sims » Fri Jul 09, 2010 2:56 pm
PetrolDave wrote:...
DRC on extended warranty, or Audi goodwill?
PetrolDave
Post by PetrolDave » Fri Jul 09, 2010 7:16 pm
drcarrera wrote:what other SC work did you have done (if you don't mind me asking).
1) Oil pipe corrosion
2) fuel pressure sensor
3) spare wheel well cracking
Plus SW update to 0090, and DRC replacement.
All paid for by Audi UK despite my car being 3 years 11 months old.
Oli133
Post by Oli133 » Tue Jul 13, 2010 2:43 am
hey bud
I had mine done just after the oil pipes split!! luckily i was only doing a short ttip so noticed a huge oil patch on the drive a few hrs later!
best nit was it was ion for a service 3 days later so they done it and replaced the oil free of charge! 289 quid for a service! now thats value!
happy days!
