Is this a £1650 repair?
Quote from Audi for this little scrape - £1650. Is this as OTT as it seems?
Any suggestions for a good alternative bodyshop - London area
RE: Is this a £1650 repair?
I own a bodyshop is wiltshire so i have some knowledge of this type of repair and it seems from the photo like a very excessive price for repair, it looks like both damaged parts would repair and should be more like £500 ish at a guess, what is the breakdown of costs?
p.s looks the same as my car, phantom black saloon?
looks excessive for me, that will surely be the price of new body parts rather than a touch up repair?
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
Thanks fellas, this is the breakdown:
RENEW L/R DOOR PROTECTIVE MOULDING
PARTS Price Part No. Price Part No.
1 x L/R DOOR MOULDING £14.25 8E0 853 963B GRU
1 x L/R DOOR LOWER COVER £32.59 8E0 853 969 7DL
1 x L/MOULDING BADGE £17.94 8E0 853 601
1 x L/R DOOR INSULATION £11.85 8E0 863 981B
1 x L/F SILL MOULDING £84.47 8E0 853 373Q 01C
1 x L/R SILL MOULDING £35.67 8E0 853 375Q 01C
1 x L/SILL PNL EXTENSION £110.69 8E0 853 859D 7DL
1 x L/R EXTENSION COVER £13.81 8E0 853 579E 7DL
1 x L/EXTENSION MOULDING £7.96 8E0 853 985B 7DL
1 x L/S WINDOW BOND KIT £22.28
1 x SIDE WINDOW PRIMER £7.50 D 009 20002
1 x CUTTING FILAMENT £10.64 357 853 999A
1 x SUNDRY PARTS (@ 3.5%) £12.94
Paint
L/R DOOR MOULDING NEW PART PAINT K1R
L/R LOWER DOOR MLDG NEW PART PAINT K1R
L/LOWER SILL TRIM NEW PART PAINT K1R
L/R DOOR REPAIR PAINTING <50%
L/R SIDE PANEL REPAIR PAINTING <50%
L/R DOOR HANDLE SURFACE PAINT PLAST.
DE NIB .
MACHINE POLISH .
PREPARATION FOR PRE-PAINTING
Other
LABOUR
CHECK L/OUTER SILL PANEL
Check AND CLEAN CAR
Check AND QUALITY CONTROL
OTHER
5052 RESET
BUTAL TAPE
E.P.A. CHARGE
CAR CARE KIT
Refit
R + R L/WATER DEFLECTOR
R + R LEFT ROOF DRIP RAIL
R + R L/ROOF MOULDING (B-PILLAR TRIM REMOVED)
R + R L/B-PILLAR TRIM
R + R L/SILL COVER INCLUDES: R + R COVER MOULDING
R + R L/FR SILL PANEL COVER
R + R L/R SILL PANEL COVER
R + R L/R DOOR TRIM INCLUDES: R + R INNER TRIM COVER
REMOVE/REFIT LH REAR DOOR HANDLE (WITH DOOR TRIM PAD REMOVED
R + R L/R LOWER DOOR COVER
R + R L/R DOOR CHANNEL MOULDING
R + R L/R DOOR HANDLE TRIM
R + R L/R INNER DOOR SEAL
R + R L/R WHEELHOUSE SHELL (WHEEL REMOVED)
R + R L/D-PILLAR TRIM INCLUDES: R + R UPPER A-PILLAR TRIM, U
R + R REAR BOOT TRIM
R + R L/R SILL COVER
R + R LEFT TAILLAMP
R + R L/R SIDE WINDOW (D-PILLAR TRIM REMOVED)
R + R R/R WHEELHOUSE SHELL (WHEEL REMOVED)
R + R LOCK CARRIER COVER (REAR BOOT TRIM REMOVED)
R + R REAR BUMPER COVER INCLUDES: R + R BOOT SIDE TRIMS
R + R REAR SEAT CUSHION
R + R REAR WHEEL (WHEELS)
Materials
PAINT/MATERIALS
Estimate Summary
Gross
________________________________________ Discount
________________________________________ Net
LABOUR 720.00 0.00 720.00
MATERIALS 218.73 0.00 218.73
OTHER 116.45 0.00 116.45
PARTS 382.59 0.00 382.59
TOTALS 0.00 £1,437.77 Plus VAT
Paint
DE NIB .
MACHINE POLISH .
Other
LABOUR
Check AND CLEAN CAR
OTHER
5052 RESET
BUTAL TAPE
E.P.A. CHARGE
CAR CARE KIT
Refit
R + R LEFT TAILLAMP
Materials
PAINT/MATERIALS
Estimate Summary
Gross
The quote lists a lot of items that are not relevant to that area. Is there any other damage on the carthatthey have also included for?
I can't tell from the photo, but they are listing items on the rear door to be changed - is there any damage above the sill? Looks from the quote like they are repairing the rear door as well.....
It is a difficult area to repair. I have a nick out of the same mouding and the repair is obvious and to do it properly would mean new parts unless you have a repairer who is particulalrly good and filling and profiling althought this is inherently weaker that an intact undamaged part. Hence why Audi have taken the route of replacing all parts as new as part of their policy.
An independent body shop would do the filler / profiling cheaper if that is what you are after however if that white line on the top part of the moulding is a crack rather than a deep scratch in the picture I would be inclined to have that part replaced.
But that is just me.
