Hi all,
Need some help. Rear pads/discs and front pads and discs need replacing. Considering doinf myself. Cant find the article in forum that has step by step guid to DIY brake replacement. My question is is it easy and where can I source the parts. Can has done 55K and on second set of discs and pads. I had the original problem of damage to the discs from the pins and was able to get first set changed under warrenty. I have the same problem again so would like to do the change myself. Look forward to the advice
Mark
Brakes again!
I can probably extract the relevant bits from the Audi official e-manual.
Fronts are definitely easy. Both discs and pads. Rears look it too, with one exception that I THINK you may need to unhook handbrake cable, which is more about being different than hard.
Might not be until end of week that i get time to look in ElsaWin. PM me to remind me if you like.
Users browsing this forum: Google [Bot] and 100 guests
