RS4 clutch problems
rogerscott
RS4 clutch problems
Post by rogerscott » Sat Mar 03, 2007 6:46 pm
has anybody had clutch problems with there RS4, clutch disintegrated after 1900 miles had a new clutch fitted under warranty still had problems went back to audi again new parts fitted under warranty still not total happy with clutch feel another vist to audi coming on
alex_123_fra
Post by alex_123_fra » Sat Mar 03, 2007 8:07 pm
Can you give us an idea of your driving style and extent of mechanical sympathy.
Don't know about RS4 clutches but if you launch, ride and generally do lots of very quick shifts, you cannot expect an OEM clutch to last very long, especially on a 4WD car.
Manufacturers make this a weak point intentionally as warranty claims for clutches are much cheaper than for gearboxes.
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
PetrolDave
Post by PetrolDave » Sun Mar 04, 2007 6:12 pm
There was a problem on early RS4's where one of the pipes to the clutch was the wrong size causing the clutch to slip on rapid high rev gear changes and was replaced under warranty.
fredfunk1975
Post by fredfunk1975 » Mon Mar 05, 2007 10:50 am
I have had my clutch replaced not under warranty though! Mine failed after doing a track day, and it was down to me really working the gears hard! I know that next time i am on the track i will be a lot more sympathetic with it!!!
Have they changed the fly wheel as well?
rogerscott
Post by rogerscott » Mon Mar 05, 2007 5:55 pm
thanks for replys the 1st time the clutch assembly was changed 2nd time they replaced modified clutch slave cylinder pipe, had car since may 06 only 5900 miles so do not use car every day drive it quite hard when i do and this car has not been on a track yet but i am used to 4 wheel drive cars as my last car and now my wife's car is S4 2.7 V6 and the clutch lasted 50k, audi never mentioned the fly wheel is that a problem i know that when clutch goes it can damaged the fly wheel, it seems that when car is driven hard for a while the clutch starts to stick and slip
Jezzer
Post by Jezzer » Mon Mar 05, 2007 6:42 pm
rogerscott wrote:thanks for replys the 1st time the clutch assembly was changed 2nd time they replaced modified clutch slave cylinder pipe, had car since may 06 only 5900 miles so do not use car every day drive it quite hard when i do and this car has not been on a track yet but i am used to 4 wheel drive cars as my last car and now my wife's car is S4 2.7 V6 and the clutch lasted 50k, audi never mentioned the fly wheel is that a problem i know that when clutch goes it can damaged the fly wheel, it seems that when car is driven hard for a while the clutch starts to stick and slip
Need to check if the flywheel has got a blue colour to it which would indicate that it has got hot, if it has ask for it to be changed at the same time.
Misano Red RS4 B8 450 PS
Phantom Black RS4 B7 444 BHP
Users browsing this forum: dan32v and 76 guests
