ABS and ESP Lights
Posted: Fri Jan 20, 2006 2:18 pm
by Gee
On my drive to work today both the ESP and ABS lights came on the dash. I switched off the ignition and on again and the OK light came on but the ESP and ABS lights stayed on.
Anyone have any idea as to why this would happen all of a sudden?
RE: ABS and ESP Lights
Posted: Fri Jan 20, 2006 2:21 pm
by david7m
My ESP light came on when one the motion sensors was faulty. I think there is two sensors to detect the direction of the car, one from front to rear and another left to right. They work together in conjunction with the ABS to operate the traction control.
Mine was replaced under warranty ;)
Posted: Fri Jan 20, 2006 2:29 pm
by TarmacTerrorist
You could also check to see that the battery is not it's way out.
esp and abs suck loads of power on start up, if the battery is failing it can sometimes get the car started but will not fire up abs or esp.
Posted: Fri Jan 20, 2006 5:28 pm
by Gee
I've noticed that my rear brake discs are close to needing replaced could this cause any probs with the above?
Is it just a case of getting a VAG Com check done to find the problem?
Posted: Fri Jan 20, 2006 6:59 pm
by DuncS3
Get a VAG COM check - it could be anything but if those lights are on you should have an error logged
Dunc
Posted: Fri Jun 16, 2006 12:15 am
by Firbee
I've just had exactly the same problem, the cause turned out to be a failed speed sensor that provides input to the esp. All up the stealership billed me £202 inc VAT to sort it. £55 to confirm problem, £41 for the part and the rest for labour!!
Posted: Fri Jun 16, 2006 8:48 am
by jons3
my ABS/ESP lights kept coming on, but always went out again when you turn the engine off and on again. Ended up being a front to back motion sensor according to Audi. £100 for the part, £100 labour.
seems to have fixed it, but I only had it done earlier this week
Posted: Mon Jul 17, 2006 11:46 pm
by shineydave
mine have just come on. any idea where the sensor is in the car?
Posted: Tue Jul 18, 2006 8:39 pm
by davidhodgkinson
On the s3 the lateral sensors are under the steering wheel dave
Posted: Tue Jul 18, 2006 9:21 pm
by shineydave
cheers, i'll have a look on etka and see if i can identify it.
Posted: Tue Jul 25, 2006 10:56 pm
by shineydave
turned out to be a faulty MAF eventually
