Door Switch
Posted: Thu Nov 10, 2005 1:38 pm
by Gee
Hi all I've had my 2002 Nogaro Blue S3 for a month now and am loving it :D
The only thing is I have a slight problem with the door intermitently not showing closed on the dash. Where is the door swith located so I can have a look at it as I suspect that its as simple as a loose wire causing it.
Graham
Posted: Thu Nov 10, 2005 10:49 pm
by Hopsta
G with a noggy blue S3, blimey i thought i'd gone back in time ! :)
(ex-owner btw)
The info you're looking for is here..... Linkymejig
Posted: Mon Nov 21, 2005 5:21 pm
by moose
the door switch is located in the door catch, its a one piece unit containing the catch,lock,deadlock and switches,all a3,tt and s3 ( as well as vw,seat and skoda) use the same type - its common for one of the components to fail - usually water ingress is the main cause and in colder climates this can freeze and cause the door to stick, its quite easy to replace - takes about half an hour
