ABS and ESP Lights
ABS and ESP Lights
On my drive to work today both the ESP and ABS lights came on the dash. I switched off the ignition and on again and the OK light came on but the ESP and ABS lights stayed on.
Anyone have any idea as to why this would happen all of a sudden?
RE: ABS and ESP Lights
My ESP light came on when one the motion sensors was faulty. I think there is two sensors to detect the direction of the car, one from front to rear and another left to right. They work together in conjunction with the ABS to operate the traction control.
Mine was replaced under warranty
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat
- 5th Gear
You could also check to see that the battery is not it's way out.
esp and abs suck loads of power on start up, if the battery is failing it can sometimes get the car started but will not fire up abs or esp.
Too much is bad.
Plenty is better.
Plenty is better.
I've just had exactly the same problem, the cause turned out to be a failed speed sensor that provides input to the esp. All up the stealership billed me £202 inc VAT to sort it. £55 to confirm problem, £41 for the part and the rest for labour!!
Misano RS4 (B5), MRC Custom Map , Quick shift, Milltek Exhaust and Downpipes, B7 Front Brakes
- shineydave
mine have just come on. any idea where the sensor is in the car?
Dave
- davidhodgkinson
- shineydave
cheers, i'll have a look on etka and see if i can identify it.
Dave
- shineydave
turned out to be a faulty MAF eventually
Dave
