Xenon headlight adjustment
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
r5bmb
Post by r5bmb » Sat May 28, 2005 12:52 am
Hi guys,
I changed my battery 2 weeks ago, and the ECU is ok but my headlights were all over the place.
I know someone with a code reader that when plugged in came up with "headlamps not adjusted" but wouldn't let me clear the code.
I adjusted the lights to the right level, and it was ok, driving home tonight i noticed they've gone funny again. :?
Does anyone know if they can be adjusted with VAG Com or is it a trip to the dealers??
Andrew
Hopsta
RE: Xenon headlight adjustment
Post by Hopsta » Sun May 29, 2005 7:55 pm
How di you adjust the lights ? if it was just with a screwdriver then that's why they have gone cod again ;)
AFAIK you need to use a VAG-Tool set the lights up to be adjusted and then use the screwdriver. Once you're happy with the height etc you set set the level with VAG-tool and then thats where the self adjusters will work from.
Graham
Always check your nuts before you have a play ! [img]images/graemlins/crazy.gif[/img]
r5bmb
Post by r5bmb » Mon May 30, 2005 2:00 am
looks like a trip to the dealer, or i might have to invest in VAG COM.
Andrew
Return to “S3 (Typ 8L) 1999-2003”
