S3 Air box mod
S3 Air box mod
Simon, Dunc, Mick etc..
More info here.
http://www.tt-quattro.com/forum7-6/foru ... D=538&PN=4
last post particularly on page 3 ( box to change pages is in bottom RH corner)
Vagcom logs more air through the maf (got to be a good sign?)
but there is mention that there might be a slight increased in lag.
However, im sure if we didnt cut as much out the box, it could be reduced, but still get a increase in induction sound and performance too?
noise was lovely tho on demo drive.
More info here.
Re: S3 Air box mod
Had a look at the cut up box attached [img]images/graemlins/roflmao.gif[/img]
What's the point in having an air filter in there, they have cut holes underneath the filter so it's basically just sitting there scratching it's balls.
Thanx but no thanx.
Bass. [img]images/graemlins/s3addict.gif[/img]
Thanx but no thanx.
Re: S3 Air box mod
air is sucked in from the bottom.
all air still has to go through the filter.
Just gives more induction noise, and a bit more airflow.
Re: S3 Air box mod
Yeah your right sorry.
Bass.
Bass.
Re: S3 Air box mod
I'm going to do this pretty soon then, a cheap mod and if its no good only £40 quid to put right
Dunc
Dunc
Re: S3 Air box mod
Me too. [img]images/graemlins/biggrin3.gif[/img]
Tell us how you get on.
Bass.[img]images/graemlins/s3addict.gif[/img]
Re: S3 Air box mod
Hi chaps,
Just thought I'd comment on this one as I saw it in passing. Are you guys seriously considering cutting holes in your airboxes????? [img]images/graemlins/062802beat_prv.gif[/img]
The standard airbox is actually a very good design with a cold air feed from the grill. Why would you want to let lots of hot air from around the engine in? Am I missing something here?... I dont think this mod would have a beneficial effect because as soon as the engine gets hot your inlet temps will go up through the roof due to dragging hot air from around the engine and hence the boost would be backed off. [img]images/graemlins/suicide.gif[/img]
Max
Revo tuned Leon Cupra R
Re: S3 Air box mod
I had considered the heat, but like Wak, thought it would be a better solution and less prone to heat than a full on induction kit, which i just wouldnt do. It also would retain the audi look under the bonnet.
I would have bought a spare airbox to play with, so i could revert to standard.
Ill knock this idea on the head for now and give it some more thought
Re: S3 Air box mod
Yep, thats much better, enclosed filter with cold air feed. You'll get much better results out of that. [img]images/graemlins/thumbs.gif[/img]
Max
Re: S3 Air box mod
...so much so that mine's blown the end cap (MAF side) clean off!
AmD Stage 6 1.8T 20V
Re: S3 Air box mod
I need a new filter like those
Re: S3 Air box mod
decided i will stick with standard.
