Cruise retro-fit?
Posted: Wed Oct 24, 2012 9:51 pm
by Sijones
The cruise "stalks" seem to be available on eBay for about £70. The sellers claim they just need connecting to the ecu and then the ecu reprogrammed by Audi or specialist. Seems too good to be true to me- does anyone know if this is the case? Surely there must be additional sensors to fit etc?
Simon
Re: Cruise retro-fit?
Posted: Thu Oct 25, 2012 2:25 am
by MaLicE
think you need the steering wheel slip ring that it plugs in to then just use Vag Com to enable it, google it there are loads of guides...
Posted: Thu Oct 25, 2012 9:33 am
by marv
Someone else asked this a short while back - see my 2 responses starting here:
http://forum.rs246.com/viewtopic.php?f= ... se#p548734
Posted: Thu Oct 25, 2012 9:40 am
by marv
Basically you might need a new steering column control module (depending what type yours currently is).
You will need a new lower steering column cover (fairly cheap piece of trim available from Audi).
You will also need access to a Vag Com cable to reprogram your steering column/wheel, your ecu & your brakes to be cruise compatible (or you can take it to a garage, or friendly forum member for them to do it for you).
It's easy enough to do yourself, if a bit scary.
