Aux rad leak
Posted: Fri Oct 01, 2010 8:21 pm
by Thacker
Ok, serviced today, I have a aux rad leak, which I believe is common, what sort of price should I be looking at? Are there 2? is it worth getting both changed?
Cheers in advance.
RE: Aux rad leak
Posted: Sat Oct 02, 2010 12:30 am
by HYFR
£600 + ... yes there are two, and yes they both leak
RE: Aux rad leak
Posted: Sat Oct 02, 2010 9:16 am
by Thacker
Is there a quality issue? Where do they leak from? Repairable? Should I replace with OE or is there an upgrade available?
20 questions! Cheers
RE: Aux rad leak
Posted: Sat Oct 02, 2010 11:12 am
by Thacker
Just priced them at £145 each. I've not actually seen them does anyone know if they are plastic end caps? Just wondered about having them recored?
RE: Aux rad leak
Posted: Sat Oct 02, 2010 11:32 am
by xyber
One rad is oil, the other is coolant so only replace the one, which I'm guessing is passenger side (coolant)
Re: RE: Aux rad leak
Posted: Sat Oct 02, 2010 1:47 pm
by Thacker
xyber wrote:One rad is oil, the other is coolant so only replace the one, which I'm guessing is passenger side (coolant)
Are you sure? I was under the impression there were 2 aux coolant rads?
RE: Re: RE: Aux rad leak
Posted: Sat Oct 02, 2010 2:25 pm
by xyber
Drivers side is an oil rad. You can get an upgrade kit for it with a more efficient oil cooler that gets relocated directly behind the grill
Posted: Sat Oct 02, 2010 7:47 pm
by Thacker
I have an oil leak at the front end too, so could well be that then!?
Posted: Mon Oct 11, 2010 9:50 pm
by caiss4
Very interesting. Mine has just sprung a leak at the front end, nearside. It's going to the dealer on Wednesday. This'll be the second radiator in 7 years.
Not a enviable record.
Posted: Tue Oct 12, 2010 2:13 pm
by R33
I actually feel better reading this. My nearside aux rad has leaked for the last 9 months but only a cup full max a week so I've not done anything about it, I just check and fill up. Now my oil rad looks to be leaking a tiny bit but not much. I might have to get this seen too soon but I at least feel better that the leak is probably the rad not the engine.
Posted: Thu Oct 14, 2010 3:24 pm
by caiss4
Well both rads are leaking coolant apparently (so I don't know where the oil cooler part is!?). Cost to replace both £700!!
Not a happy bunny but I like the car too much so....deep breath, relax!
Posted: Thu Oct 14, 2010 5:17 pm
by xyber
I wonder if it's an air to water oil cooler/heat exchanger then? It's definatly part of the oil cooling system because the upgrade kit deletes that rad and a replacement oil take off plate is bolted to the side of the block and a new oil rad is fitted just behind the lower grille. The space left is just the right size to fit a dirty great centrifugal supercharger.
It may be cheaper to get the rads made, rather than buy from Audi? But a suspect a fair bit of that £700 is labour fees
Posted: Thu Oct 14, 2010 10:06 pm
by infrasilver
It could well be the rads leaking but just check that the headlight washer is not leaking onto the rad.
Mine was and it was diagnosed as the rad until I noticed the colour of the fluid was blueish like washer fluid not orange/pink coolant fluid.
Posted: Tue Oct 26, 2010 11:44 am
by caiss4
In the end the total cost of replacement for both aux rads was £670. The rads were about £140 a piece.
I asked for the rads that were removed so I now have two apparently leaking radiators! To answer other questions on this thread they have plastic end caps. Also they are a different design on each side; one has inlet/outlet on one end, the other has them at each end plus they are slightly different sizes. (well, at least the 2 rads I was given are)
