Air con issue
Posted: Sat Sep 23, 2006 3:42 pm
Noticed this post browsing the RS4 forum:
http://www.rs246.com/index.php?name=PNp ... ic&t=56034
I've always been troubled by the same issue on my B6 - with the system set to auto, the fans (or at least the air flow) increase with speed; even setting the fan speed to minimum, the air flow into the cabin is always uncomfortably fast at motorway speeds. Up 'til finding that post, and then driving my brother's '06 330 Sport last night (in which, at speed, with the system on auto, there is very little air flow once the set temp. has been reached), I'd assumed it was an Audi characteristic, but it seems it may actually be a fault. Anyone else's B6/7s do this?
Oh and as a sideline, the 330, whilst pretty rapid (we've had a few playful drags), actually felt substantially less planted to the road than the S4 - sure, there's more feel on turn in, but you just can't beat the Audi's 4-wheel drive stability that gives you so much more handling confidence. The 330's also surprisingly cosseted, meaning on the motorway it's supremely comfortable (much less wind/tyre noise than the S4), but on acceleration (now that I've got used to the V8 rumble), it sounded, well, pretty pathetic
Dash is awful too, but the sports seats are exceptionally good; much better, stronger & more comfortably positioned head restraint than the S4.
