New Brakes
cobraBLACK
Re: New Brakes
Post by cobraBLACK » Tue Feb 10, 2015 4:23 pm
How have those with the MTEC discs found them after all this time?
I'm considering those after getting a quote of £230 for just the front discs from Audi.
I've also heard good things about Tarox G88 discs but the cheapest I can find those for is about £330 from Demon Tweeks or Larkspeed. I'm not sure the performance improvement over OEMs would be enough to justify the extra £100.
Audi S4 Avant (B6, 2004) in Goodwood Green.
cobraBLACK
Re: New Brakes
Post by cobraBLACK » Tue Feb 10, 2015 4:58 pm
Also, I asked MTEC about the difference between drilled and dimpled and they said:
The discs would be performance part and there would be no difference in the design.
This would be down to your own preference.
I don't really know what that means.
Does anyone else have a comment to make?
ASC
Re: New Brakes
Post by ASC » Tue Feb 10, 2015 5:51 pm
I have EBC turbo grooved and dimpled discs with Yellow Stuff pads. According to EBC's bumff the dimple is meant to have a similar function to the drilled hole in that it lets gases escape but being dimpled doesn't weaken the disc like a drilled hole all the way through would.
FYI, I was well happy with this set up until a couple of weeks ago braking from speed I noticed I was getting shudder through the pedal and wheel. The discs have only done like 3k miles. I'm looking into having them skimmed, bit of pita! :(
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
cobraBLACK
Re: New Brakes
Post by cobraBLACK » Tue Feb 10, 2015 6:44 pm
Thanks for the response.
I've heard that about EBC discs.
cobraBLACK
Re: New Brakes
Post by cobraBLACK » Wed Feb 11, 2015 2:13 pm
I've found those Tarox G88s for £313 now.
I'm thinking about just doing the fronts for now and leaving the rears for a later date.
Possibly with EBC Yellow Stuff pads.
SevenR
Re: New Brakes
Post by SevenR » Thu Feb 19, 2015 3:04 pm
I called Demon tweeks and got Black Diamond discs with Predator pads last April. They had just came out for the S4's. So far they have done me ok, although I feel it doesn't matter what discs or pads you fit, the brake set up on my S4 is not good enough for the weight of the car. Braking from very high speed they do struggle a bit and the initial bite is still a bit duff. In the ideal world, I would want an RS4 set up on the car which I believe is easy to do as all Audi braking is modular. Just the cost which has stopped me so far.
http://www.ebay.co.uk/itm/Audi-RS4-b7-2 ... 35e4726304
cobraBLACK
Re: New Brakes
Post by cobraBLACK » Thu Feb 19, 2015 5:28 pm
I know what you mean; I looked at a few big brake conversions but they're 2-3 grand.
I think another option is brakes from a Touareg or a Cayenne but they're still a lot more than a basic disc upgrade.
