BRAKE warning
spidey1
BRAKE warning
Post by spidey1 » Fri May 27, 2011 5:51 pm
newbie to the forum and S4's! just got '04 plate s4 cab few weeks ago. this morning i started up with the normal short duration rattle and i got a brake warning on dash with 3 beeps. disappeared in a couple of seconds so i didn't get to see too well as was doing other stuff and not concentrating. I can't fathom how to find out what it actually said. it quickly chnaged to 'OK' and when i start now it checks and says 'ok' everytime. manual says 'stop' for any red warning but as intermittent at best is this a real fault. do i worry?
N
xyber
Re: BRAKE warning
Post by xyber » Fri May 27, 2011 6:48 pm
Nope. Mines had the occasional hissy fit with the brake warning light. I even scanned it and got nothing. Never had it happen again either. I would worry
cobraBLACK
Re: BRAKE warning
Post by cobraBLACK » Sat May 28, 2011 7:54 am
I had the same; got it checked out, they found nothing, never happened since.
You do get occasional random warnings when your battery's on its way out.
Audi S4 Avant (B6, 2004) in Goodwood Green.
R33
Re: BRAKE warning
Post by R33 » Sat May 28, 2011 9:28 am
I've had this, it was low brake fluid due to pad and disc wear. Topped up and problem solved! :)
spidey1
Re: BRAKE warning
Post by spidey1 » Sat May 28, 2011 7:43 pm
thanks guys. i'd checked fluid level and all ok, just been serviced so i was surprised to see it. as it disappered so quickly and then read 'ok' i was hoping it was an intermittent gremlin. will keep an eye out for it happening again.
pmgire
Re: BRAKE warning
Post by pmgire » Sun May 29, 2011 10:46 pm
I have often got this warning.It seems intermittent alright and each time it has happened I have scanned with VCDS to find no fault codes.I dont worry about it!!
S4 Brill Red
aligod78
Re: BRAKE warning
Post by aligod78 » Tue Jun 14, 2011 11:06 am
When I test drove my S4 cab and threw it around hard it did this. It's the level sensor, has to be topped up exactly to the right level. Then it stopped. Well, until I did some spirited driving the other day and it did it again. But level is just about spot on, could do with a top up.
Edmond
Re: BRAKE warning
Post by Edmond » Wed Jun 15, 2011 11:40 pm
Interestingly I just had this happen today on my b6 avant whilst I had my Vag Com plugged in. Just suddenly did it - even when I wasn't in the abs module. Ran a check - no code.
Very odd!
(hello everyone by the way) I recognise a lot of names on here from *ahem* other Audi boards!
Users browsing this forum: No registered users and 11 guests
