Suspension Knock - Advice Needed
Posted: Sun Sep 26, 2010 9:42 am
Hi
I've recently noticed a knocking sound coming from the front offside suspension particularly on uneven surfaces and it seems more so when turning left. I thought maybe a balljoint has gone so took the wheel off yesterday. All the balljoints seemed ok (no splits in the rubber or leaks)
I put the wheel back on and with the car still off the ground, pulled on the wheel. I noticed when pulling on the back of the wheel there was some movement and a knocking at the top of the hub carrier where the 2 upper arms join. I'm thinking that maybe the bush in one of the upper arms is worn. Possibly the rear of the 2 arms as this one seems to move more.
Can anyone advise if my diagnosis seems correct? Also noticed a split CV boot so will have to that at the same time.
