want it slammed
Posted: Mon Jan 19, 2009 11:54 am
by rotta
ive had a search about and am strugling to find the info im after due to my complete noob-ness i want to slam my s4 but just above each wheel is a suspension arm that hardly gives me any clearance on my 235/18/40 oettinger wheels, how do you get around this problem? does this need changing to a different shaped arm or when installing coilovers does this not affect????
Cheers Chaps
Rotta
Posted: Mon Jan 19, 2009 12:59 pm
by Soupie69uk
It will not affect it. Only would go closer to the wheel if you put on a wheel with a higher offset or a chunkier tyre.
Just get some coilovers and then some spacers to pull the wheel out as it will look a bit better.
Posted: Mon Jan 19, 2009 1:58 pm
by rotta
cheers soupie i want it about your ride height what setup you usin? does that suspension arm stay where it is and the car lowers around it then?
Posted: Mon Jan 19, 2009 2:36 pm
by Soupie69uk
I have FK front shocks and H&R rears.
(got the rears super cheap hence the mix and match)
Yeah think of it like if you have 3 people in the back and stuff in the boot its not goint to rub. It just moves with the suspension and the wheel will not move any closer to it.
