wires
Posted: Sat Mar 08, 2008 3:55 pm
by g60bv
are there any switch live wires in the engine bay which is adequate for the the relay on a water injection set up. doesn't have to be a powerful one. just dont want to hook into an ecu or important one. what about one under the passenger side.?
RE: wires
Posted: Sat Mar 08, 2008 5:37 pm
by s4woody
just open up the ECU box and feed a wire from the fuse board and pass it through the box..safer that way..and it,ll be fuse protected..
RE: wires
Posted: Sat Mar 08, 2008 7:03 pm
by g60bv
gotcha
Posted: Sun Apr 13, 2008 8:13 pm
by g60bv
ok
how do you get to the back of the box to get a wire in it.?
Posted: Sun Apr 13, 2008 8:15 pm
by quattronutter
i wired mine into the washer pump fuse
by redrod
I have seen neat little hole drilled in, and then a nice gromet to seal it.
RR
Posted: Sun Apr 13, 2008 8:28 pm
by g60bv
but i cant actually get to the back of the box. woundering if ts worth getting to the back of the radio.?
Posted: Sun Apr 13, 2008 8:35 pm
by spen
lift the ecu out. then drop your wire down the hole. With a bit of luck you'll find it near the brake pedal. or if not drop a straightened coat hanger down then tape your wire to it from the inside. Then in the engine bay retrieve your coat hanger.
Posted: Mon Apr 14, 2008 11:31 am
by g60bv
i can get the wire into the car. as you've said . but how do you get to the back of the fuse box. it seems encased in a metal chassie, and a load of trim. with no obvious screws...
Posted: Mon Apr 14, 2008 4:16 pm
by bobbler
Isn't the 75X terminal a switched live which you could use instead?
Posted: Mon Apr 14, 2008 5:42 pm
by g60bv
'Bobbler' the 75x terminal. ? whats that. and where is it.?
ta
Posted: Mon Apr 14, 2008 7:26 pm
by bobbler
Have a look at the install instructions for the AWE boost gauge here -
http://www.awe-tuning.com/media/pdf/ventgauge.pdf (300kb)
Step 11 shows you it, its where I have my gauge wired here for the lights and it only comes on with the ignition.
Its just in the fuse box area by the drivers side, just drop the lower panel down to get at it.
Posted: Mon Apr 14, 2008 9:06 pm
by g60bv
sweet thank you.
Posted: Mon Apr 14, 2008 10:30 pm
by flashyg
Once you have wired it in, should you drop in an in line fuse and switch in to be safe? Not sure if it will be fused.
Posted: Tue Apr 15, 2008 8:01 pm
by g60bv
ok got the wire in. found a load of other stuff under there. a charging lead to something. see pics.
also looks like a relay is missing. any ideas.?
