Page 1 of 2
Bosch fuel pump part number
Posted: Wed Feb 06, 2008 10:33 am
by BRETTCOLLINS
Any one know the Bosch fuel pump part number.
RE: Bosch fuel pump part number
Posted: Wed Feb 06, 2008 11:06 am
by JonnyX
058 0254 044
Posted: Wed Feb 06, 2008 11:21 am
by BRETTCOLLINS
thats good. same unit as my mates are using in the high powered cosworths.
Posted: Wed Feb 06, 2008 1:18 pm
by JonnyX
Mine was 90 quid new from ebay.
Posted: Wed Feb 06, 2008 1:25 pm
by BRETTCOLLINS
Cool
Posted: Fri Feb 08, 2008 7:32 pm
by Keihin
Is this S4 or RS4?
Posted: Sat Feb 09, 2008 12:52 am
by BRETTCOLLINS
it can be used in both, it is an after market item
Posted: Sun Feb 10, 2008 7:49 pm
by Keihin
Ok, so how does it compare to the stock ones? I believe that the stock S4 pump does not flow enough when upgrading with K04s. How "far" does this one keep up?
Posted: Mon Apr 21, 2008 1:59 pm
by BRETTCOLLINS
Is this the pump needed
Bosch 0 580 254 044 Inline Fuel Pump
Bosch 044 fuel pumps mount inline (out side of your gas tank), most commonly rear center under your car or truck. Each Bosch 044 inline fuel pump provides 300LPH of flow and operate at 72.5 PSI. Bosch 044 fuel pumps are comparable to the Walbro 255LPH high pressure inline fuel pumps which can both support vehicles for up to 600-700 horse power. Can be used in sequence with an intank Walbro or Bosch 040 fuel pump.
Bosch 044 Fuel Pump Specs:
Bosch Part Number: 0 580 254 044
Minimum Current: 12 Volts
Operating Pressure: 72.5 PSI (5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In-Line
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 1030 Grams (2.27 Pounds)
Fuel Pump Connections:
Inlet: M18 x 1.5
Outlet: M12 x 1.5
Electrical: Positive M6 / Negative M5
Posted: Mon Apr 21, 2008 2:34 pm
by dummi
that is the one most people use
Posted: Mon Apr 21, 2008 2:35 pm
by BRETTCOLLINS
many thanks
Re: RE: Bosch fuel pump part number
Posted: Tue Apr 22, 2008 10:54 am
by GHH
BRETTCOLLINS wrote:Is this the pump needed
isnt there also an intank version? or have i got it mixed up.
RE: Re: RE: Bosch fuel pump part number
Posted: Tue Apr 22, 2008 11:07 am
by BRETTCOLLINS
thats the 040 not the 044
Posted: Tue Apr 22, 2008 3:23 pm
by JonnyX
My 044 is mounted in-tank. I used the V8 Audi 80 strainer and basket.
Posted: Tue Jul 22, 2008 10:18 am
by mattsimis
Sorry for the bump, but could you clarify if its ok to mount a Walbro 255lph inline pump intank in place of the stock S4 pump?
