Page 1 of 2
Started gutting my RS4 downpipes......
Posted: Thu Jan 17, 2008 5:48 pm
by AdamS4
RE: Started gutting my RS4 downpipes......
Posted: Thu Jan 17, 2008 6:00 pm
by JonnyX
I've never seen anyone even bother to cut them open. Mihnea used an Auger, a chisel
and a blatant disregard for his own safety!
. Took him less than an hour to do my S4
ones....
smash the bejeesus out of them!
Posted: Thu Jan 17, 2008 6:07 pm
by satanschild
i just cut them out and got a new bit of tube and sleved it over and then welded them up ....
Posted: Thu Jan 17, 2008 6:08 pm
by AdamS4
Posted: Thu Jan 17, 2008 7:14 pm
by s4woody
bosh it..bosh it..BOSH IT...
Posted: Thu Jan 17, 2008 9:00 pm
by AdamS4
I was thinking... What would Jock do ??...
BOSH IT !!!!
LOL
Si, you got a welder to hand ? If so, you know what my next question will be
Posted: Thu Jan 17, 2008 11:20 pm
by Philws4
Did mine a couple of weekends ago but didn't go down the route of cutting them open just perservered with some auger wood bits and a 20mm or 25mm staret hole cutter,then pliers and 'old' screwdrivers and lots of patience.
Took me best part of 3.5 hours but worth the effort and not a weld in sight
Well worth the time though Adam, you will be well pleased with the results when they are fitted.
Posted: Fri Jan 18, 2008 1:04 am
by rosshyslop
Hey, what were the steps taken to get the dp's out? What do you have to remove and in what order? Fancy doing this myself too!
Cheers, Ross.
Re: Started gutting my RS4 downpipes......
Posted: Fri Jan 18, 2008 1:20 am
by rolskii
AdamS4 wrote:I'll let the pictures do the talking.....
Anyone know of a quicker way to get the cat stuff out ???
I did a post - 18mm auger bit on a 24v bosch drill - big fukkin chisel - apple core them.... collapse them in on themselves and pull em out ...
not even a quarter wot yr doing.....
RE: Re: Started gutting my RS4 downpipes......
Posted: Fri Jan 18, 2008 2:23 am
by s4woody
yes mate i have a welder and can do them no probs..when your ready give me the nod..or i could do it when i fit the FMIC..let me know whats best..
Posted: Fri Jan 18, 2008 1:51 pm
by carpy
Hmm nice work. What kind of power increase would be achieved from this? Assuming of course the car is mapped to take advantage
Posted: Fri Jan 18, 2008 3:35 pm
by GrahamS4
carpy wrote:Hmm nice work. What kind of power increase would be achieved from this? Assuming of course the car is mapped to take advantage
I'd say no peak power increase, greater peak torque starting lower in the revs and peak bhp holding for longer.
Posted: Fri Jan 18, 2008 4:18 pm
by Doug_S2
if you were cutting it - why not cut half the cylinder off around the cat and pull it out in one go? then weld the half cylinder back on - then the DPs won't need jigged to make sure they line up ok???
Posted: Fri Jan 18, 2008 4:38 pm
by TopBear
Doug_S2 wrote:if you were cutting it - why not cut half the cylinder off around the cat and pull it out in one go? then weld the half cylinder back on - then the DPs won't need jigged to make sure they line up ok???
Doug, how easy does the cat material seperate from the outer casing?
Is it a case that you can just pull the cut casing piece away and the cat will lift out.
Posted: Fri Jan 18, 2008 6:44 pm
by AdamS4
