Screenwash
Posted: Sun Oct 14, 2007 12:07 pm
by stark
My car leaked about 5 litres worth of screenwash last night after washing my windscreen... Had a similar issue on my old A4 but that was just a case of reattaching one of the hoses which had become lose.. Access in the S4 is very limited, and im finding it difficult to see where exactly the problem lies... Any ideas?
RE: Screenwash
Posted: Sun Oct 14, 2007 12:33 pm
by Blue_Thunder
Check the pump. It's a common fault on these. When mine had gone, it literally cracked right the way up the plastic and was very obvious.
Add some more water to the car so you can see where it's coming out from.
RE: Screenwash
Posted: Sun Oct 14, 2007 1:56 pm
by shineydave
you'll have to remove the N/S wheelarch liner to see properly, 5 minute job
RE: Screenwash
Posted: Sun Oct 14, 2007 5:56 pm
by MarkB
Just found a puddle under mine and plenty of drips underneath so may be suffering the same...
RE: Screenwash
Posted: Sun Oct 14, 2007 6:38 pm
by mad-for-tar
Mine leaked at the T-junction behind the front bumper LH grille, O-ring was squashed, took me ages to find the leak, new o-ring, some patience and all was sorted.
Re: RE: Screenwash
Posted: Mon Oct 15, 2007 12:42 am
by mattsimis
MarkB wrote:Just found a puddle under mine and plenty of drips underneath so may be suffering the same...
The AC drips condensation around the area too. I thought I had a leak after replacing the headlight washer pump when I just got the car. It was of course split up the middle, such a poor designed part.
RE: Re: RE: Screenwash
Posted: Mon Oct 15, 2007 2:04 am
by docwyte
If you've been running the AC and stop the car, it's the drain from the AC. If it's wiper fluid, you've either cracked the tank, or had the pump O-ring drop into the tank.
Replacing the tank is easy, but you do have to remove the drivers side wheel and inner fender liner.
Posted: Mon Oct 15, 2007 6:19 am
by jeffw
Or passenger side wheelarch liner and wheel if your not American....
Re: RE: Screenwash
Posted: Mon Oct 15, 2007 8:48 am
by MarkB
Looked like I had water dripping off the anti roll bar. The AC puts out water further back doesn't it?
I'll be keeping an eye on mine now...
Posted: Tue Oct 16, 2007 11:45 pm
by stark
Not had time to do any investigation so far this week, washer light has been on since saturday - its beginning to get annoying now! Will see what i can do over the weekend, does the wheelarch liner simply slip off? Im a noob when it comes to car maintenance, guess ill have to learn the hard way... Cheers for the help
