Part no requests
Posted: Fri Apr 13, 2007 8:06 pm
by nickb834
I'm trying to locate some part numbers for the stock B5 RS4 brake discs.
I'm not after the VAG part numbers but rather the Brembo part no's.
AFAIK the calipers are made by Brembo, well mine have Brembo stamped / cast into the caliper body.
Is it Brembo that make the discs or someone else?
Any idea's - forum search doesn't reveal much :-(
RE: Part no requests
Posted: Fri Apr 13, 2007 9:00 pm
by yorkie
Etka list 8DO615301P left and 8DO615302B right - special order oem only
Posted: Fri Apr 13, 2007 11:50 pm
by nickb834
Cheers Yorkie, but them's the VAG group no's that I'm not after :-P
I'm hoping to find out who makes them for VAG and see if can source anywhere else.
Basically, I object to paying 300+ vat for a pair of discs with only 1mm of wear each side before new ones are required....
Perhaps I'm just a tight northerner :-)
Posted: Sat Apr 14, 2007 12:35 am
by nickb834
looks like my only option is the GMBH drilled disks - ah well, £300 plus vat it is then
Posted: Tue Apr 17, 2007 5:15 pm
by eddiecrawford
why can you not get the old ones machined, esp if its only 1mm wear(!)
Posted: Tue Apr 17, 2007 8:23 pm
by mad-for-tar
I have a Brembo catalogue on CD at work. I can look up the part numbers tomorrow for you when I get to work, if thats any good...
Posted: Wed Apr 18, 2007 8:12 am
by mad-for-tar
Just had a look and it does'nt list anything for the RS4. Thats buggered that plan up! :(
Posted: Wed Apr 18, 2007 1:07 pm
by nickb834
eddiecrawford wrote:why can you not get the old ones machined, esp if its only 1mm wear(!)
I don't have any old ones! That's why!
Basically funds don't stretch to RS4 B7 Discs / Calipers etc etc I got a pair of B5 RS4 calipers for practically nowt and now just need disks.
Seeing as the disks don't have alot of wear in them and they ain't exactly cheap AND I'm into my first year of ownership - there's a potential for me to have to change these discs maybe twice more (do 18k miles a year - mostly cross country no motorways) over the life of the car I'll feel a bit ill knowing I spent a grand on brake discs.
It gets hard to justify RS4 disks when the stock S4 disks can be had for a ton.
Posted: Thu Apr 19, 2007 10:38 am
by eddiecrawford
doh! :oops:
" don't have any old ones! That's why! "
