S4 install RS4 intercoolers
Posted: Wed May 17, 2006 11:20 am
by kamming
Is it necessary to change S4 both sides lower and upper hoses when installing RS4 intercoolers? Or just change both the upper hoses will do......... Thank you for your input.
RE: S4 install RS4 intercoolers
Posted: Wed May 17, 2006 11:41 am
by s4woody
when converting to RS4 intercoolers you have to use both top and bottom hoses from either an RS4 with a piece of s4 hose at the joint to take up the diff size in hoses or use RS4 to s4 hoses already made for the conversion..
Posted: Wed May 17, 2006 1:47 pm
by JonnyX
I would suggest getting the hose conversion kit from Forge Motorsports if they still do it. This has the 4 reducing
hoses you will need. You will also need to source the lower intake hard pipe from the RS4 (offside I think). I assume
you realize you will also need all brackets, nuts and bolts etc. I can recommend Dialynx for the install, they did a pretty
good job (relatively speaking) of mine.
Posted: Wed May 17, 2006 2:07 pm
by Nige_RS4
Samco do a kit for the RS4 IC's on an S4 - about £65 from memory.
Re: RE: S4 install RS4 intercoolers
Posted: Wed May 17, 2006 3:40 pm
by JonnyX
Nige_S4 wrote:Samco do a kit for the RS4 IC's on an S4 - about £65 from memory.
Yes, that's the kit I got from Forge.
Posted: Wed May 17, 2006 5:32 pm
by davs4
Mine too
RE: Re: RE: S4 install RS4 intercoolers
Posted: Thu May 18, 2006 12:11 am
by BRETTCOLLINS
takes over a month to get it,
Posted: Thu May 18, 2006 8:40 am
by KayGee
APR pipe kit from ECS does the same job, dearer but usually in stock.
Posted: Thu May 18, 2006 9:21 am
by kamming
Thanks guys.
I found APR kit is way too expensive. Samco seems more reasonable. May I know the contact details?
Posted: Thu May 18, 2006 10:05 am
by Nige_RS4
Try www.forgemotorsport.co.uk - they no longer stock Samco stuff, but might still be able to get the kit for you.
If you don't have any luck with Forge, try contacting Samco direct ... www.samco.co.uk
Posted: Thu May 18, 2006 3:00 pm
by MarkB
Found this and thought it might be helpful... http://www.goapr.com/Audi/support/s4_in ... ctions.pdf
