DEAD TURBO 2
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
jimbogrey
DEAD TURBO 2
Post by jimbogrey » Wed Mar 29, 2006 10:29 am
As per post on track day day forum, turbo gone, local garage say blades possibly in contact with housing causing whinning sound from 1500rpm and half throttle.
I presume there has been a bearing failure, however thare was no noise from the turbo previously and when it happened (changing from 2 to 3rd) there was an instant and total loss of boost. all hoses checked nothing obvious.
Question would the car detect a turbo failure and go limp immediatly.
there is nothing showing on vagcom apart from an out of limits reading which was there before.
ZeroK66
RE: DEAD TURBO 2
Post by ZeroK66 » Wed Mar 29, 2006 10:44 am
Dear me, sorry to hear that!! Sorry cant help with the VAG-Com issue. Hope a nice set of shiny K04's make it into the engine bay and this becomes patrially worthwhile.
SimonS4MTM
RE: DEAD TURBO 2
Post by SimonS4MTM » Wed Mar 29, 2006 10:58 am
Boost loss may happen because turbo stalled when the blades hit housing
jeffw
RE: DEAD TURBO 2
Post by jeffw » Wed Mar 29, 2006 11:51 am
Sorry to hear that....hope you get it fixed soon.
s4woody
RE: DEAD TURBO 2
Post by s4woody » Wed Mar 29, 2006 12:50 pm
jimbo will have some info about the k0,s soon.. :thumbs:
GARTH ROAD MOT CENTRE LTD
020 83353032
jimbogrey
Post by jimbogrey » Wed Mar 29, 2006 1:11 pm
thanks for the concern
I am still able to drive the car.....must now be the slowest S4 in the world....to prevent turbos spooling up i have to drive at 1/10th throttleand no more than 3000 rpm so 0-60 about 45 seconds :lol:
Well you've gotr to laugh or you'd cry especially with a £3500 bill around the corner
jimbo
tartan_rob
Post by tartan_rob » Wed Mar 29, 2006 2:43 pm
you can use vagcom to reduce boost pressure. one of the engine adaptation channels.
2017 Kawasaki Z1000
2014 RS6
2014 S1
DavidT
Post by DavidT » Wed Mar 29, 2006 7:27 pm
Sorry to hear that, been there.
If you are getting the siren sound it is likely a turbo is toast.
You probably have a boost leak as well.
There is a way to stop the car requesting boost, MRC Doug told me but I've forgotten what it is. Recommended as you may be super lucky, some boost leaks sound similar to turbo death.
The ECU cannot detect turbo failure unfortunately.
rolskii
Post by rolskii » Wed Mar 29, 2006 11:21 pm
What happens when you spool up jimbo, does it whistle like a good-un ....? or does it lock up..?
My first S4 had an HKN chip from new, it was running same turbo,s as new as far as I was aware, in the winter my friends could hear me 2 roads away....... :lol:
went just as well coz i got bored of the noise and bunged some new k03's on that I had lying around,(after 2.5 years!) made no difference in performance, if anything with the pressure sensing pipe fixed(had a crak on banjo coupling) it was slower, because it didnt overspool anymore......... :?
I still have the old turbo's and you can see where they were both stiking the compressor housing, for along time... b@stard when they do go though :thumbsdown:
@Tartan Rob..... can you dial up the b/pressure that way .. or is it capped ..?
David :thumbs:
MarkB
Post by MarkB » Thu Mar 30, 2006 12:13 pm
Hi Jim
Sorry to hear about your problems... any more news on what needs fixing.
Shame you missed the Windsor Meet last night. It was a good turn out.
Mark
mrwang
Precausion
Post by mrwang » Fri Mar 31, 2006 2:35 pm
Hi there, Sorry to hear about your blower. Same thing happened to me last year. As a precausion Kim @ QST told me to disconnect the cables to the N75 valve. This will stop them trying to boost above 0.5 bar or something around that. Good luck with the KO4s, the only way is up now!
Ben
