crankshaft oil seal
Posted: Fri Mar 24, 2006 7:17 pm
by tan
just had rear crankoil seal done took it back to garage still had a slight leak there told me the front one needs replaceing now gutted :cry: :cry: :(
RE: crankshaft oil seal
Posted: Sat Mar 25, 2006 1:03 am
by s4woody
if ya front 1 is leaking then do the cambelt cos oil on a cambelt aint good..also the tensioners and water pump..sorry to be the bearer of bad news but its what needs to be done..
Posted: Sat Mar 25, 2006 8:52 am
by smurfbus
is the leak now on the front? If still rear it could be upper oil pan, rear main seal, valve cover gaskets or cam adjuster seal.
I've had a good amount of leaking on the right rear (valve cover and tensioner seal) for the past year and a half which I intend to fix this spring. no other inconvenience but smell coming inside when not moving.
Posted: Sat Mar 25, 2006 9:51 pm
by gav
you have hit the nail on the head cheers
