Wheel Spacers for S4
Posted: Mon Nov 21, 2005 9:01 pm
by lellaS4
I am trying to clear a set of Movit brake calipers without rubbing the tyre on the wheel arch - so I am looking for 5mm (or less) wheel spacer with the correct tapered lip that fits the standard 17" wheel and hub - not a MTM version with a lip.
Anyone with any thoughts on how I can achieve this???
RE: Wheel Spacers for S4
Posted: Tue Nov 22, 2005 4:27 pm
by snbS4
You may be able to source hubcentric spacers from AMD or OCT tuning, depending on where you are.
Rgds
Simon
K04's, Tanoga, full Milltek, H&R, S4 B6 alloys, RS4 calipers and drilled discs, AWE DTS,
Posted: Tue Nov 22, 2005 4:53 pm
by gavsteryoung
I got some 5mm spacers from a guy on here called Philwalker, you could try PM'ing him. They are made by Eibach.
Previosuly I had some cheapo 3mm spacers but there was not much metal involved..... 3mm looks best 5mm makes the wheels stickout a little to far. Believe it or not the extra 2mm can be seen.....
Posted: Tue Nov 22, 2005 8:48 pm
by CliveH
Yes, try Philipwalker on here - he sorted me out for these
Posted: Tue Nov 22, 2005 8:58 pm
by lellaS4
Thanks guys,
Did yopu have any problems with rubbing with 5mm spacers - it looks very tight under them arches!
Posted: Tue Nov 22, 2005 9:02 pm
by CliveH
Not problems at all, but I have the B6 18" wheels and stock calipers
Posted: Tue Nov 22, 2005 9:08 pm
by kevinw
Phil Walker on this forum got some for me - they are the Eibach hubcentric 5mm. Needed them to clear 18" B6 wheels as per Clives.
Posted: Tue Nov 22, 2005 9:59 pm
by tdiquattro
Have a look at this, I had a problem with the B6 18" S4 alloys not cetering at the front on 5mm eibach spacers, (the rears were fine with 5mm) The hub is not long enough to engage the wheel and you can see it isnt centred when you have tightened the bolts, so...... Add 4 blobs of weld, machine down the spacer to 3mm and a taper to exactly fit the wheel !!...........
[img]modules/pnCPG/Coppermine/albums/userpics/10567/rs246_norm_Copy%20of%20IMG_0438.JPG[/img]
[img]modules/pnCPG/Coppermine/albums/userpics/10567/rs246_norm_Copy%20of%20IMG_0441.JPG[/img]
[img]modules/pnCPG/Coppermine/albums/userpics/10567/rs246_norm_Copy%20of%20IMG_0439.JPG[/img]
Posted: Tue Nov 22, 2005 10:49 pm
by philipwalker
With Eibach and H+R you only get the "lip" to locate the wheel on + 10mm spacers, this would throw the offset out.
Some wheels have a non taper spigot ring, so the fit is better on the thiner rings.
