RS4 Dual mass flywheel conversion to one mass
Posted: Wed Mar 09, 2005 10:28 am
(i'm putting this issue to this section also because it doesn't get much hits in modification section)
Hi, I got a RS4 flywheel and resurfaced it. Then I got and idea to lighten it. I have opened the FW and removed the springs and stuff from inside. The original FW weights 12 kg, and now it is ~8 kg. I would still like to lighten it some more, but is it worth it? It could be done by removing material from the "back disk", and with that it could weight about 6-7 kg. There is also a small problem how to attach these disks together. I am a little scared that how would it last?
And then about these harmonic vibrations, are those so big issue that the whole project is worthless? I know that people are using one mass flywheels, but not like this. Or should I just "plug and play"?
Here is some pictures what I have done:
http://www.valitalo.org/rs4_flywheel_machining.htm
Comments?
Comments?
