AMD four wheel alignment? recommendations?
Posted: Thu Nov 04, 2004 8:40 pm
by vw_nutta
I live in Luton, Beds. I need my s4 setting up properly on a 4wd alignment, I've seen they do it at AMD and i've been pleased with there work before.
Anyone had the same work done at AMD? Any other recommendations?
cheers
Posted: Mon Nov 08, 2004 2:15 pm
by Dippy
Yes. They do a proper job and will tune your alignment for the type of driving you want. My camber is quite aggressive so that I get maximum tyre contact when cornering. Downside is that the inner edge of the tyres wears out first.
Posted: Mon Nov 08, 2004 8:45 pm
by vw_nutta
cool.
S4 Alignment
Posted: Mon Nov 08, 2004 9:09 pm
by S4RS4
Dippy wrote:Yes. They do a proper job and will tune your alignment for the type of driving you want. My camber is quite aggressive so that I get maximum tyre contact when cornering. Downside is that the inner edge of the tyres wears out first.
I understand that the only way to adjust the camber is by the ride height unless you have fitted adjustable suspension links. How do AMD do this?
Posted: Tue Nov 09, 2004 10:01 am
by Prawn
On the rear there is some adjustment, you can get around -1 deg, on the front no adjustment so camber is a function of the ride height. Ride height of 25.5" (65CM) from ground to wheelarch will give around -1.5~1.7 deg camber.
If you go much lower on the ride height you will start to suffer from bump steer.
Posted: Tue Nov 09, 2004 2:43 pm
by Dippy
In my case they did it at the same time as fitting the H&R coilovers (and lowering the car).
