Suitable oil for a modified B5 S4
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
MarkB
Re: RE: Re: RE: Suitable oil for a modified B5 S4
Post by MarkB » Thu Mar 29, 2007 8:10 am
C9CRM wrote:So was that 10W60, 5W40, or 0W40????
I've used Total Quartz 9000 Fully Synthetic Engine Oil
5 Litres 5W40 long life oil for £15 + VAT from GSF then less RS246 discount
RS246 discount??
Chris
5W40
RS246 discount see here... http://rs246.com/index.php?name=PNphpBB ... ic&t=55199
Mark
GrimReaper
RE: Re: RE: Re: RE: Suitable oil for a modified B5 S4
Post by GrimReaper » Thu Mar 29, 2007 11:28 am
I recently did an oil change and put the usual mobil 1 0W40 normally even with a bit of spirited driving it barely goes over 100 degrees. On the way back from MRC from the remap the long trip on the M5 was showing increasing oil temps. Doug told me to keep an eye on it and use thicker oil if keeps getting hot. Sure read somewhere that 40 oil starts to break down at around 115 degrees so think to be safe the summer months will be run using something a bit thicker especially when i go the Ring in August.
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
QuantumJohn
Post by QuantumJohn » Thu Mar 29, 2007 11:50 am
Quantum Synta Gold 5W-40
John
viperbl
Post by viperbl » Thu Mar 29, 2007 12:53 pm
ZeroK66 wrote:Even with an oil cooler I have seen my car get slightly over 120 when having fun. I am glad I have the 10w60 as recommended by MRC. That said though it does concern me for my brief journeys to and from work where the engine does not even get warm enough to move the oil temp needle.
Good excuse for me to cycle into work more often... and I have been. Not helping my weight (see off topic post lol).
:lol: :lol: :lol: Looks like I am gonna be in the same situation soon!
I intend to use 10w60 when I get it back up and running, reason being I do play a lot and see some high temps with my RS4 engine, can't remember now exactly where it would go to ... I have the RS4 oil cooler.
I only live a couple of miles from work (been walking for two months now!! shock, horror, I thought driving was the only way!) so might just have to continue walking so as not to hurt the new turbo's! :?
RS4 B5 Saloon8) with 750+ bhp :D
S4TAN
Post by S4TAN » Thu Mar 29, 2007 1:55 pm
10w60 Castrol EDGE sport fully synth for me ....
Deus ex machina
dace
Post by dace » Thu Mar 29, 2007 4:51 pm
GrahamS4 wrote:What oil do RS4 owners use? Wyy are we different? The RS4 has a stock oil coolder and we don't?
What sort of money is the oil cooler as a retro fit mod? Should we be looking to use 0W40 oil but fit oil coolers due to our tuning not alter the oil?
Graham, I use Synta Gold 5w40 in my RS4. Change the oil and filter every 4,000 miles. I used the same oil in my modded S4 also. Oil temp never goes above 100..........
I have a brand new oil cooler on the car so this probably helps with the temperature.
droberts
Post by droberts » Sat Mar 31, 2007 4:56 pm
MarkB wrote:I remember the days of 5W50 oil. Harder to come by these days
If you're looking for a compromise, CAS do the Valvoline VR1 5W50 fully synthetic http://www.central-auto.co.uk/ about £28 IIRC. I tend to run 5W50 full-synth in winter and 10W60 semi-synth in summer, temps tend to be 120c when pushing on with both grades of oil.
Milltek dual cat-back, gutted downpipes, ECS Tuning stage3 brakes, MRC custom map, H&R ARBs.
ZeroK66
Post by ZeroK66 » Sat Mar 31, 2007 8:47 pm
do sounds good to me... 5w50 sounds spot on, may run that next winter. Great find doc!
dace
Post by dace » Sun Apr 01, 2007 8:33 am
Never use semi synthetic in these engines, always full synth.
mattsimis
Post by mattsimis » Sun Apr 01, 2007 10:17 am
The engineer that put in my KO4s said that at stock, 5w40 would be fine, but when remap'ed and tuned etc, 10w60 (fully synth of course) was what he would recommend. As it happened he couldnt source 10w60 at the time, so we fell back to 10w50. As mentioned above, with the hotter engine temps remaping will induce, he strongly advised against Xw40 grade oils.
S4TAN
Post by S4TAN » Sun Apr 01, 2007 10:30 am
Yep - i was advised the same: 10w60 due to the higher temps of a k04/fuelled/re-mapped car.
Deus ex machina
MarkB
Post by MarkB » Sun Apr 01, 2007 10:32 am
S4TAN wrote:Yep - i was advised the same: 10w60 due to the higher temps of a k04/fuelled/re-mapped car.
Julian, what oil did you use before the K04's?
Mark
S4TAN
Post by S4TAN » Sun Apr 01, 2007 11:12 am
I used 0w40 (Castrol EDGE sport again) on the k03s ... when i "went k04" Doug advised the oil change to 10w60 because of the turbos and high temps ...
Deus ex machina
droberts
Post by droberts » Tue Apr 03, 2007 1:22 pm
dace wrote:Never use semi synthetic in these engines, always full synth.
5W50 is fully synth, but I didn't think you could get a fully synthetic 10W60. Castrol state "synthetic technology" or something like that but it's a semi-synthetic, Valvoline is definitely semi-synthetic, IIRC Millers is semi-synth, but if you know of one please tell...
