sticky ashtray !!
sticky ashtray !!
anybody have a solution to fixing the inherent problem of my( b5 with symphony) ashtray hanging on to my spare change !?
Refuses to release so i have to prise it open with a pen when i need to pay for a parking ticket.
any solutions ?
cheers ally
any solutions ?
cheers ally
RE: sticky ashtray !!
Clean it.
Take it out, Get a brush, clean it with ispropyl soution, and then brush the unit on the car to that the ashtray sits in. Clean all the dust and any gunge that may be stoping it from sliding it and out, then put it together then all should be fine.
IF that doesnt work then try someone elses ashtray and see if the same thing happens. Make sure there ashtray works, at least you can determine which end is giving you problems.
- shineydave
bet there's a coin stuck in there, i had an annoying rattle from mine and the occasional sticky incident, stripped it out and found a pound in there, bargain, my car cost me a quid less
get a strong ruler and force the coin out of the way. I had the same... it will scratch your astray a bit but you can polish that out.
Never enough...
Re: RE: sticky ashtray !!
ok but need to find another car to try swap as its done this since brand new !saf wrote:Clean it.
even got new one under warrantyfew years back but still the same !?
think it could be something to do with the housing its in .
jb7_uk
RE: Re: RE: sticky ashtray !!
i got similar issue with my Prefacelift car - the ashtry which i assume you are just supposed to ush and then have it slide out (some kind of sprung mechanism?) just plain refuses. i was once able to prize it open, but then pshed it back in to see if i'd fixed it ... but i hadn't. think there might be a sring missing or un-attached somewhere... anyone else seen this in there pre-face car?
FOR SALE
B5 S4 - 1999 (Pre-Facelift) - Ebony Black Pearl - 18" RS4 (B5) Reps - 710n's - replaced N75 - After-run Pump mod - APR Bipipe.
See Classifieds ad (HERE) for more details.
My ash tray's just fecked.. been like that for years so if anyone has any part numbers or exploded diagrams of how to replace it.. I'd be interested
98/Missano/Bose/Carbon
Re: RE: Re: RE: sticky ashtray !!
Excuse me bringing this post back from the dead, but did you ever sort your problem?jb7_uk wrote:i got similar issue with my Prefacelift car - the ashtry which i assume you are just supposed to ush and then have it slide out (some kind of sprung mechanism?) just plain refuses. i was once able to prize it open, but then pshed it back in to see if i'd fixed it ... but i hadn't. think there might be a sring missing or un-attached somewhere... anyone else seen this in there pre-face car?
quattronutter
RE: Re: RE: Re: RE: sticky ashtray !!
buy a wallet to keep change in?
Users browsing this forum: No registered users and 113 guests
