Snapped rear subframe
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
GDS968
Post by GDS968 » Fri Nov 14, 2008 6:03 pm
You also need to check around the rear toe adjustment bolt as mine had also cracked up through the bracket from just beneath the bolt to well above it meaning you then need a new subframe as mine did, its almost impossible to weld this area!
MRC for the brackets or make your own as I did. Easy bolt on job though.
s4-99
Post by s4-99 » Fri Nov 14, 2008 8:57 pm
Doug_S2 wrote:it is only going to get worse so get that welded asap and support brackets on there to stop it happening again.
I'm going to look into getting it welded one day next week, just gotta find someone who can do a decent job.....
Can you still supply the support brackets Doug or can you get them? I'm due a good health check aswell so maybe could tie it in together?
Hmmm, its fast but is it fast enough!!!
s4-99
Post by s4-99 » Fri Nov 14, 2008 9:01 pm
GDS968 wrote:You also need to check around the rear toe adjustment bolt as mine had also cracked up through the bracket from just beneath the bolt to well above it meaning you then need a new subframe as mine did, its almost impossible to weld this area!
Nice one, i'll have another good look tomorrow and hopefully i wont find anything else :) .
s4-99
Post by s4-99 » Mon Nov 17, 2008 1:32 pm
tdiquattro wrote::( 2000 facelift, stiff, fat......
:) 6mm metal plate and some less than attractive welding, £30, job done. (same the other side)
That's a good price you paid for the work you had done. I've been quoted £100 to have the cracks welded and a plate put on each side similar to tdi's.....
Does £100 pound sound steep or did tdi get a bargain job done.....
Also would i still need to fit the brackets or would the welded plate be enough?
stapo69
Post by stapo69 » Thu Nov 20, 2008 9:14 pm
Well after reading all this I just had to go out and have a look under mine as I've had a mystery knocking from the rear of mine for bloody ages now and still not solved it, also setting up the heights for the coilovers to match the arches either side there seemed to be quite a difference from one side to the other in the amount of threads that were left to get it all sitting level, however at a quick glance there doesn't appear to be any cracking anywhere from what i can see with just the car sitting on the ground. I will investigate further when I get chance.
I guess this should get picked up on MOTs? Any more pictures of all the places I should be checking? Looked where other people have had faults but want to check thoroughly.
s4-99
Post by s4-99 » Fri Nov 21, 2008 9:45 pm
Does anybody know if the welded plate will be enough without fitting the bracket's?
Thanks in advance....
KayGee
Post by KayGee » Sat Nov 22, 2008 12:14 pm
My subframe has gone too! Oh dear this is gonna hurt the wallet......
Anyone got a spare subframe for a saloon pre facelift?
s4-99
Post by s4-99 » Sun Nov 23, 2008 11:22 am
KayGee wrote:My subframe has gone too! Oh dear this is gonna hurt the wallet......
Is it gone that bad it cant just be welded?
KayGee
Post by KayGee » Mon Nov 24, 2008 8:10 am
Find out Friday, hopefully can be welded and strengthened with some support plates.
aikihook
Post by aikihook » Sat Nov 29, 2008 6:07 pm
Offside just started knocking - more than a bit broke? :cry:
Offside rear banging in the wind
S4 - Silver 2000
KayGee
Post by KayGee » Tue Dec 09, 2008 5:07 pm
Fixed now, suspect the tyre idiots that fitted the Dunlops did it.
I thought the tyres were shockingly bad since never felt planted since they were fitted in March..........
However now the subframe is fixed they feel 300% better. Whats the betting they jacked the car up on the ARB mounting plate?
g60bv
Post by g60bv » Tue Dec 09, 2008 9:14 pm
holy <beep>. ..
gunno try for compo..?
MRC TUNED 480BHP . -SOLD 1.9TDI AVANT 215HP. HYDBRID TURBO. SMOKING
KayGee
Post by KayGee » Wed Dec 10, 2008 6:46 pm
I wish, they were about as helpful as H&R.
Users browsing this forum: No registered users and 61 guests
