Engine oil smell gas!?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Mikse
Post by Mikse » Fri Jun 06, 2008 11:58 am
I checked engine oil level today and it was over upper limit and it smelled gas. What could cause this?
2001 S4 Avant
Blue_Thunder
RE: Engine oil smell gas!?
Post by Blue_Thunder » Fri Jun 06, 2008 12:23 pm
If the map is overfuelling it could be washing the boards, the excess petrol will then contaminate your oil making it too thin.
Mikse
Post by Mikse » Sat Jun 07, 2008 7:39 am
I actually have had this problem before and after remap (stage1->stage3) so I don´t think that´s the reason, of course it´s possible. If this was caused by a mechanical fault where should I be looking at?
2001 S4 Avant
Blue_Thunder
Post by Blue_Thunder » Sat Jun 07, 2008 12:01 pm
Unless your stage 1 remap was also overfuelling?
Mikse
Post by Mikse » Tue Jun 10, 2008 6:09 pm
Yep, overfuelling like cracy! On idle it´s OK but when you raise rpm it just fuel like there´s no tomorrow! :(
Now the question is WHY? I called to my tuner but he couldn´t really say why it´s overfuelling. I logged blocks 32 and 33 with vag-com and both lambdas correct ~10-15% (+-3%) to leaner on part throttle (at +2000rpm). After maybe a 5 minute normal run "learning lambdas" was correcting ~7% leaner. (sorry my english but hopefully get the point :D )
I believe it´s bad mapping but is there anything else that could cause that much overfuelling.
PS. I have 630cc injectors, they are quite a large but souldn´t be a problem if tuned right.??
2001 S4 Avant
Blue_Thunder
Post by Blue_Thunder » Tue Jun 10, 2008 7:28 pm
Mikse wrote:PS. I have 630cc injectors, they are quite a large but shouldn´t be a problem if tuned right.??
I think that's your answer right there!
Probably worth getting in touch with Mihnea or Doug at MRC to get a professional opinion.
I would guess maybe the tuner is using a base map for different injectors, hence the overfuelling. I may be wrong...
Mikse
Post by Mikse » Mon Jun 16, 2008 3:24 pm
Just a quick confirmation, The injectors are Siemens Deka 630cc/ml @3bar. So these are generally used injectors on our cars and shouldn´t cause problems with fine tuning the fuel mixture especially at idle and low rpm and low/no boost?
2001 S4 Avant
Doug_S2
Trader (Expired)
Post by Doug_S2 » Tue Jun 17, 2008 12:45 pm
who tuned your car?
best to get a wideband on the car and see what it is doing part throttle and wot.
i would be surprised if you are washing the bores so much as to add fluid to the oil that you can measure - you do get fuel in oil but not 100mls worth!
http://www.MRCtuning.com
Mikse
Post by Mikse » Tue Jun 17, 2008 1:17 pm
Doug_S2 wrote:who tuned your car?
The car was tuned by a local tuner but apparently didn´t do a very good job. As I said mixture is ok at idle but when reving it the CO raise up to 8!!! (0,06 at idle) And there IS so much fuel in oil that 100ml propably isn´t exaggerated. :(
And the last but definately NOT the least, tuner refuses to tune the car because the he thinks 630cc is too big so I may have to go back to stage 1 map I had unless I find another tuner.
Doug, I´ve heard that you guys can make custom maps "remotely" at the MRC, could you help me on this. I´d be more than grateful :!:
2001 S4 Avant
snadge
Post by snadge » Tue Jun 17, 2008 1:56 pm
I would also be extremely interested in this, I would imagine it is possible.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Tue Jun 17, 2008 2:24 pm
send us an email with your specs
Mikse
Post by Mikse » Wed Jun 18, 2008 1:25 pm
Doug_S2 wrote:send us an email with your specs
btw do you tune foreign car also? I guess it´s the same where the mail comes from..?
2001 S4 Avant
Blue_Thunder
Post by Blue_Thunder » Wed Jun 18, 2008 1:44 pm
Mikse, reading this but again, have you fitted the new bigger injectors without having a remap done???
If this is the case then of course they will be overfuelling as they duty cycle will be set too high for these injectors.
Mikse
Post by Mikse » Wed Jun 18, 2008 3:25 pm
Blue_Thunder wrote: Mikse, reading this but again, have you fitted the new bigger injectors without having a remap done???
No, remap is done and the injector size "should" have been compensated but maybe the tuner isn´t quite good with these cars as I thought and now he say the injectors are too big and refuses to tune it right... :(
Waiting reply from MRC if they are willing to do the map for me.
2001 S4 Avant
snadge
Post by snadge » Wed Jun 18, 2008 4:42 pm
Keep us informed on the " tune by email" procedure Mikse.
Users browsing this forum: No registered users and 36 guests
