APR bipipe fitting experience
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Did you have any issues when fitting your APR bipipe?
Fitted without problem
2
11%
Difficult to fit, but no actual problems
6
32%
Easy to fit but had problems (specify)
6
32%
Difficult to fit and had problems (specify)
5
26%
Total votes: 19
shineydave
RE: APR bipipe fitting experience
Post by shineydave » Mon Sep 10, 2007 8:18 pm
(only the best fairy)
Was that the Turbo Fairy?
rolskii
Post by rolskii » Mon Sep 10, 2007 8:37 pm
Had a few problems, not any seized bolts, had to belt it firmly home, after I removed the overspray of paint on the inside of the flange mount and sensor mount, one bolt went soft on final turn, buggered if I was removing it again, that was the quick bit...
Other issues include, repair the front o/s front cover as the whole encapsulted nut had ripped out, made a tasty stud repair which pulled the cover together again and reposition front pulley covers as they had jumped forward and werent located correctly, also were melting against the inside of the front pulley....... :smile_smoking:
happy dayz .... party ....
Keihin
Post by Keihin » Tue May 13, 2008 11:00 am
Just to make sure before I order: It does fit on pre-facelift?
Think it's strange that this is bolt-on for some when others have do drill?
Blue_Thunder
Post by Blue_Thunder » Tue May 13, 2008 11:45 am
Yes, it does fit on pre-facelift.
s4woody
Post by s4woody » Tue May 13, 2008 4:13 pm
thats prob because its cast aluminium and not always a good casting..
GARTH ROAD MOT CENTRE LTD
020 83353032
jb7_uk
Post by jb7_uk » Tue May 13, 2008 4:30 pm
defintely fits fine on a pre-facelift, Woody kindly fitted mine for me back in Sept and mines a pre-facelift.
FOR SALE :cry: :
B5 S4 - 1999 (Pre-Facelift) - Ebony Black Pearl - 18" RS4 (B5) Reps - 710n's - replaced N75 - After-run Pump mod - APR Bipipe.
See Classifieds ad (HERE) for more details.
SunDiver
Post by SunDiver » Tue May 13, 2008 5:44 pm
Fitted to my facelift 2000.
It was quite difficult but mainly just fiddly and I couldn't quite get one of the lower bolts back in as it didn't line up as well as it should have. Got there in the end and all was well but it took me a good couple of hours I would think...And quite a few cut fingers...!
Keihin
Post by Keihin » Tue May 13, 2008 7:37 pm
Thanks. It seems the hose kit I installed altered the angles somewhat. The result is that both lower mount point on the plastic tubes has broken, moving the left one onto the fan... Kind of fixed it with a longer bolt and a big washer, but will order a BiPipe ASAP.
Keihin
Post by Keihin » Tue Jun 17, 2008 12:26 pm
Installed! But a couple of bumps:
1. Right lower mount point broke off the cambelt shield. Not sure if it's because the round shape didn't line up or the pipe just is to hard to bend until it settles. Seems the fan doesn't touch anyway. Not sure if I will try to replace the cambelt shield.
2. Forge resirc. valves are positioned to high to refit the front engine cover. Will pinch the vacuum hoses if I press it on. Not sure if I should try to cut the hoses or turn them around. Someone told me that they're supposed to be horizontal, not vertical?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Tue Jun 17, 2008 12:40 pm
stock is the other way around - you can trim the right angle silicon hoses a bit to make them sit a bit lower
http://www.MRCtuning.com
Dippy
Post by Dippy » Tue Jun 17, 2008 1:41 pm
Every S4 I have seen has the DVs 'horizontal'. I think the point is that the air pressure comes from the bipipe side, and the way Keihin has them now this will be pushing directly against the piston and maybe could force it open???
2001 Silver S4 Avant
Users browsing this forum: Google [Bot] and 38 guests
