Clutch advice needed.
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
snadge
Post by snadge » Fri Jun 06, 2008 8:40 pm
Hi folks,
I'm in the middle of getting my clutch replaced, I'm helping to do it at my mates garage, got the box off and my flywheel and slave cylinder are both knacked.
The flywheel has 110mm play in the cush assembly, standard tolerance is 10mm so I need a new 'un.
I am putting a RS4 clutch assembly in, so can I use an RS4 slave cylinder?
Anyone in UK with a lightened flywheel in stock?
I can get a new standard flywheel monday afternoon but would prefer a lightened one if I could get it in the same timeframeish.
okkim
RE: Clutch advice needed.
Post by okkim » Fri Jun 06, 2008 9:44 pm
You don't have to change the slave cylinder, it is the same in S4.
snadge
Re: RE: Clutch advice needed.
Post by snadge » Sun Jun 08, 2008 7:25 pm
okkim wrote:You don't have to change the slave cylinder, it is the same in S4.
Ok thanks for that okkim.
Does anyone know if I could leave the existing flywheel in with that play and the new RS4 clutch, the engine is coming out for turbos etc within 1000miles, when I will replace the flywheel with a lightened version, I need the car for work and need to work to pay if you see what I mean
okkim
RE: Re: RE: Clutch advice needed.
Post by okkim » Sun Jun 08, 2008 8:53 pm
If you don't push the car hard, the old FW will be fine if it has working ok before that. Especially when you have so little time to wait for proper one.
dummi
Post by dummi » Mon Jun 09, 2008 8:10 am
I have a light weight fidanza one available immediately, where are you?
okkim
Post by okkim » Mon Jun 09, 2008 10:28 am
I think that the Fidanza is good FW, I have installed many of those.
S4
Re: Clutch advice needed.
Post by S4 » Mon Jun 09, 2008 10:39 am
110mm play, what that all about. where are these measurements taken.
Darren
snadge wrote:Hi folks,
snadge
Re: RE: Re: RE: Clutch advice needed.
Post by snadge » Tue Jun 10, 2008 8:04 am
dummi wrote:I have a light weight fidanza one available immediately, where are you?
grr... to late mate, I have had a standard one delivered now....... :cry:
snadge
Post by snadge » Tue Jun 10, 2008 8:11 am
S4 wrote:110mm play, what that all about. where are these measurements taken.
Darren
It is the rotary movement of the internal drive plate on the "shock absorber" assembly when rotated against the outer part of the flywheel.
The new one I have when you apply a rotary motion on this part, there is minimum movement, on the old one there is 110mm+ rotary movement with feeling of something catching internally.
Audi tolerance is 10mm>
S4
RE: Re: Clutch advice needed.
Post by S4 » Tue Jun 10, 2008 9:16 am
cool.... where are the instructions- specifications for this, Bentley workshop manual? im looking for a good manual for the boat... they are not really talked about much.
Darren
snadge
Re: RE: Re: Clutch advice needed.
Post by snadge » Tue Jun 10, 2008 3:12 pm
S4 wrote:cool.... where are the instructions- specifications for this, Bentley workshop manual? im looking for a good manual for the boat... they are not really talked about much.
Darren
I could tell something was up with the flywheel when we inspected it, so a quick call to Audi was made.
okkim
RE: Re: RE: Re: Clutch advice needed.
Post by okkim » Tue Jun 10, 2008 7:36 pm
Is it from side to side 10mm, or from the center?
S4
Post by S4 » Tue Jun 10, 2008 9:35 pm
come on guys.... where are the super workshop manuals on these things....
Darren
Users browsing this forum: Google [Bot] and 38 guests
