pissed off
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
MCB
Post by MCB » Thu Mar 20, 2008 11:07 am
What you have both said is spot on. :thumbs:
S4B5 Avant
ZeroK66
Post by ZeroK66 » Thu Mar 20, 2008 11:25 am
RS4 suspension I thought was 20mm lower?? So this should settle, but that far sounds a bit much. May not quite get the height at the back, but the weight diff between avant and saloon is like full tank vs empty tank of juice.
curtis11
Post by curtis11 » Thu Mar 20, 2008 11:45 am
the car sits pure <beep> looks like a standard a4 ride height there is no way its goin to settle 25mm
MarkB
Post by MarkB » Thu Mar 20, 2008 12:13 pm
Are you sure the parts are RS4?
Mark
curtis11
Post by curtis11 » Thu Mar 20, 2008 12:16 pm
i checked the part numbers and they were correct
travs
Post by travs » Thu Mar 20, 2008 2:45 pm
S4TAN wrote:
everything was done and tightened on the 4-point lift (car was in the air)
4-point or 4 post? The latter means the car can sit on full ramps though also lifted through extra jacks if need be.
2 posters have jacking point arms (albeit 2 per side hence 4-point) which suspend the wheels all the time.....
DevonMike
Post by DevonMike » Thu Mar 20, 2008 3:18 pm
My guess would be that the original S4 suspension was knackered, hence it sat lower than it should have. And then the RS4 suspension being new will probably settle, so the two things together would account for the 25mm difference.
Look on the bright side, you can ride speed humps a lot better.
curtis11
Post by curtis11 » Thu Mar 20, 2008 3:23 pm
i think i might have standard rs4 suspension, not the gmbh <beep> which sits 10-15mm lower than standard ,
what do ye think?
rolskii
Post by rolskii » Thu Mar 20, 2008 3:50 pm
imolas4uk wrote:all the bolts that fasten through bushes should be tightened whilst the suspension is in a loaded state (weight of the vehicle on the wheels) so as not to preload the bush and cause premature failiure.this applies to all vehicles not just audi s4`s :thumbs:
Take a look at the front lower rear arms, they have a locating shoulder on the subframe to b*tt up against too.... to get that flat you have to rotate the middle bush upwards(or arm...)...... upwardly ......
You can tighten bushes/arms up to chassis in this state .... if its all apart.... fit it in as a proper job on rebuild ...... :roll:
i doubt it will lower yr car though ... :wink:
I think it will be stamped or identified if its GMBH gear ...
happy dayz .... party ....
S4TAN
Post by S4TAN » Thu Mar 20, 2008 4:35 pm
4-point or 4 post?
4-point (2 posts) - the 4 lift points lift on the chassis - the wheels were hangin' free baby!
Deus ex machina
